How long (how many miles) does a clutch last?
I have a 97 Civic LX that just started having problems with the clutch. On Saturday, I noticed the clutch started squealing when I pressed on it, and I noticed a burning smell. I checked the fluid, it seems to be the correct level.
On Sunday afternoon (today), not only did the clutch squeal when I pressed on it, the power kept going off too, when I would try to start the car after being stopped in neutral. I noticed the idle was very low when the car was stopped, like about 750. The car would turn off, I would restart it, and then put it into gear. Then in the evening, when it's cooler, the clutch would still squeal, and there was some burning smell, but the power was ok, it did not keep going off like in the afternoon. The idle was higher in the evening too.
Can someone tell me how the clutch and power/battery are related, and why the power would keep going off? And does someone know what exactly about the clutch I need to repair? I know there are two cylinders, the disk, and the cable, and I was wondering does all of it get replaced when you repair the clutch (I've seen "clutch kits" etc). And how long will the car drive in this condition? I want to get it repaired asap, but I know this is a costly repair.
Any help is appreciated.
Thanks.
