Re: 88 Accord LXi Problems.
Sounds like your engine is blown. What happened that it started doing this?
Blue smoke usually means blown piston rings... And the knocking sound is most likely a rod knock.. Or valves...
Sent from my SGH-T989 using Tapatalk 2
heh, figured id get some bad news. ill be honest, i know next to nothing about cars. i thought if the engine was blown it shouldnt work anymore? either way what are my options? sounds like ill have to take it somewhere no matter what
You want to confirm that the engine is indeed blown before spending a bunch of money on it. A compression test should tell you a lot. You also want to confirm that the knocking noise is engine bearings and not pinging or a loose manifold shroud or something. Here are a couple links to get you started on that.
http://www.ehow.com/how_4510122_diag...ne-noises.html
http://www.supramania.com/forums/sho...gnosis-and-FAQ
Are you able to post a video of the noise?
of course now the sound has completely stopped. as soon as it happens again (if ever) ill try to get a video of it. had one more problem i forgot to post about. whenever im just sitting idle my engine revs up to 2000 rpm and then stops. it stops randomly or whenever i put it back into gear, any ideas guys? thanks again!
I suggest you check the cooling system for air by opening the bleeder valve on the engine with heater open and engine fully warmed up. Look for air bubbles coming out the valve and continue this until no more bubbles appear and then close the valve. This video may be helpful: http://www.youtube.com/watch?v=zUpXg...eature=related. I suggest putting a pan under the car to capture coolant dripping down during the bleeding procedure.
man thats a lot to take in, why dont high schools have mandatory car classes? anyway, thanks for the help ill check out the video!
