Ok is there anyway to convert are headlight from the Winker lights to the modern still light like the ones off of the cb7 our acuras
yes. there is the factory way which is mostly a bolt on swap, headlight brackets need to be welded on though. depending on where you are, finding the parts may be difficult
http://carborg.com/images/honda-accord-ca-06.jpg
or the more custom way of putting the CB front end on. not a bolt on swap and will require quite a bit more work to do properly. it's been done before
http://i13.photobucket.com/albums/a2...7/IMG_0477.jpg
Is there a how to on thethe cb swap an is there someone on the form that's already done it an what all would i need to do the swap besides the cb parts
The fabrication is easy i just need the parts list an ill go from there an thanks for the help
Ok so in ur own opinion would it be easier to use a Integra front end or a cb7
went digging and found this Teg frankenstien
http://www.cardomain.com/memberpage/473774
i think the da front doesnt look too bad :) http://www.cardomain.com/ride/258290...-honda-accord/
I need to speak with who ever did the 80s 3door lxi with 90s front end i have a welder and whole 90sfront front clip.
I may be new but is this not a modify front end page. Cause if i wanted stock id go and look in the repair guide. But i hate going down the road with really dim lights i live in the mountains of Mendocino Forrest. I need to see and buy a different car u wanna pay for it last time i checked 3gs were cheep and reliable so why not at least try and help for those like me loking for a how too on just that.
Well first off, if you buy a car cause its cheap then front end conversations are out as they will require a lot of money. If your headlights are dim, buy some upgrade lenses and install and HID kits. That will be just as bright as any modern car. The reason there is nothing to chime in on is, it will all have to be custom. The only bumpers that get close to "bolting" on is the 1g Integra, but that car has pop-up headlights. Anything else will need to be custom trial and error.
I remember when I first got a 86 dx, the silver car I usd to have had very poor lighting. I discovered the headlights wern't even halogens. I bought standard H6054 bulbs and made a heep of difference. Upgrading to HID would be even more phenomenal.
I was given free front end im mechanicay inclined just want a second opinion
Sounds good, take pictures of progress and stuff and post them up! I'd like to see what it turns out.
Hey I like to see a tailight conversion too since there are aftermarket versions for the 4 th gen but not 3rd gen accords.
