Where are the carb gains?
This is probably obvious but what is it about other carbs, like Webers, that makes them give horse power gains vs. stock? Is it that they have jets capable of higher fuel flow and higher CFM or is it the fuel+air mixing?
Here's my dilemma: you are not always flooring the throttle. Actually it is wasteful, right? There is a point where you get diminishing returns on acceleration even before the pedal gets to the metal. Which means that there's something about the engine displacement limiting you that is not accomplished by giving it more fuel and air. So how do the Webers and Holleys do it?
Let me wander a bit...get a little quantitative
-1 cubic foot is about (30cm)^3 = 27000cm3
-1 liter = 1000cm3
Therefore: 1CF = 27L
-Keihin carb is say 220-240CFM (based post read) = 5940-6480 L per min
-2 L liter engine draws only 1L air (fuel very minute) per revolution because intate + compression + compustion + exhaust is 2 revolutions per cylinder.
At 6000RPM, a 2L engine draws 6000 L air which is right at the the limits of the 220-240 CFM carb. But then in the 1000-4000RPM range its not like the carb is maxed out. If the engine can chomp it and wants more the carb can give it, right? You are welcome to tell me its not a perfect world and that operational limits dont dictate sub-limit efficiency of 100%. Of what though? Supplying transient demand (during acceleration)?.
Maybe I'm looking at it wrong. I know not everything is about numbers and limits. In that case what are the designs that enable HP and acceleration gains based on all the posts I saw. After all, what use are horses if you cant get better acceleration or better performance at any load bearing operation. Unless all you want is greater max speed. I know those are not oranges to oranges either due to other factors.
Re: Where are the carb gains?
1) Weber is better at fuel/air mixing and allows the carb to be adjusted via the jets and booster venturi for added response or for a slight increase in air flow.
2) Not always flooring the carb on a progressive 2-bbl carburetor is not wasteful. I think the number of fuel circuits is 4:
- IDLE (manifold vacuum controls fuel delivery here and the throttle plates keep the high vacuum signal from reaching the venturi)
- PART THROTTLE (the restriction the the plenum or runner is dropped and manifold vacuum drops the idle circuit isn't fully used and the venturi begins to recieve a vacuum signal along with the booster ventuir, and vacuum secondary.)
- WOT Idle circuit is not in use and venturi's now has full vacuum, th venturi vacuum is high enough to open the secondary all the way unless a heavier spring was used.)
- POWER VALVE (upon the drop in manifold vacuum a spring loaded plunger opens a valve releasing extra fuel.)
As you see each fuel circuit is based on engine demand and in some cases, air by way of a vacuum controlled secondary throttle.
(Vacuum secondary is controlled by engine demand based on venturi port vacuum.)
