YAY! Fixed Rear Window Trim
Hey Everybody... My rear window trim started to peel, and the corner pieces were faded, so i fixed it. the only thing I could find that matched the trim was truck bed liner!!! When sprayed in coats, it looked just right! Of course, i did have to scrape off all that old rubbery paint first. Masking off was horrible!!!
BEFORE:
http://mywebpages.comcast.net/philip...rim/before.JPG
AFTER:
http://mywebpages.comcast.net/philip...rim/after1.JPG
http://mywebpages.comcast.net/philip...rim/after2.JPG
What I used. Total of $10
Originally posted by Chris86Lxi
Please be more specific on the type of truck bedliner stuff you used.
Chris,
I used an aerosol can of Dupli-color "Truck Bed Coating" I bought at walmart in the automotive section. It looks a lot like the original trim coating. You have to make sure to do it in coats and spray from a distance, so you don't make the texture too big or bubbly looking (otherwise it will look like the underbody of your car). I did very light coats at about 7 or 8 inches from the trim. Make sure you scrape off all the old rubber stuff on any sections that are peeling; sand and paint the entire trim so it all looks the same (even the sections that are not peeling)Also make sure you mask off VERY carefully, and don't try to cover your car on a windy day :mad: . LOL
