sprint's stiffness...??
Jim, Just curious what the stiffness was on the sprints again..? If I have the sprints and Konis would I have a nice tight ride? I dont want my car to sway around turns at high speeds like it does now... I think I need sway bars too but will the springs/struts help? Thanks...
sprint
2.25" front 66% rear 192% stiffer than stock.
Yeah the springs are stiff enough that you should have allot less leaning in the turns. Koni's at least in the front should keep things under proper control. I'd hold off on the sway bar's until you've got a few miles with the setup, just to make sure you would still want them.
