I'm helping out a friend doing a timing belt on his 88 Accord LX, somehow he stripped 49 teeth off the belt...yes, I counted. Problem is this; he had his clutch done awhile back and they replaced the flywheel with an aftermarket flywheel with only 1 notch mark on it, presumably the TDC notch for timing belt changes. Here's where things get odd, the notch is exactly 180 degrees off of TDC which I verified by pulling the oil pan and setting the crank at TDC and BDC and match marking the relative positions. Is it possible on the older Accords to install the flywheel in whatever position you want or are they keyed to only install in one specific way? My friend needs their car back asap and I'm at a loss except to just use my own marks and set it based off the cranks position.....
