all motor or turbo desicions to be made... advice please...
ok i am kinda of stuck here with what i want to do...
1) my first plan was to build up a junkyard turbo with low psi and slowly build internals and supporting mods until i max out the limit of a t-25 or 14b... this would be somewhere around 15psi, no higher...
after considering this alot, it still seems like a realy fun plan, but i am scared for my engines sake.
2) the other route obviously is all motor or maybe n20... in which case i could do a lot more mods to the car that would make it fast.... HOWEVER, i am not sure how stressful this would be to an engine....
part of me wants to raise the compression ratio, and get a ground cam, but part of me wants to do a turbo setup...
i know i will ultimitly be faster with a turbo, but i am wondering whats the potential for a built a20?....
realistically i SHOULD build the car up as far as possible, doing mods that would not have to be swapped out depending on the route i chose... thats why right now i am trying to figure out this b16 intake manifold, so i can get my air and fuel delivery up to speed. i already have my suspension done, and now i am wondering what else i can do (please be specific) that would not steer me down one path or another...
i would also like opinions on which route you would take. i am not interested in a swap, i want to stick with the a20...
i DO plan on rebuilding the engine before i turbocharge it, and i would also rebuild once i started to add cams and pistons to the all motor engine...
which would be safer, smarter, and more reliable?
i guess all i want right now is to know what i can do that will stay useful and not have to be sold once i commit to one path or another...
funstick/sean has the ECM that really makes me want to go with a turbo, but it would also help out a NA car it seems...
a little insight and advice please?
