Just run it with an OBD0 PR4
this is going on hold for a while until i can sell the other accord i just bought.
then ill buy a new head gasket for it and prolly tune my obd1 ecu to run a 1.8 engine
Well, if you use the PR4, it's already tuned for that exact same engine (well almost)
I don't think you guys got the OBD0 PR4 tough.
im guessing that ECU is for a b18a1 or something, In that case yeah ive never seen one they are rare, just like a OBD1 dizzy that will fit a b20a
Yup, OBD0 B18A1
BTW, any OBD2 dizzy from a Non-Vtec B series Engine will fit our B20A for an OBD1 conversion.
indeed but currently the oem dizzy seems to be working
heres some pics, this car has been in the shed for a month but last night i got it out and put the axles in it. The B18A engine in it is still requiring its head gasket replaced but it runs for now i basically only put the axles so i can move it around the yard and give it a wash::
pics are dead..
would be good photos if my brand new camera would work
guess what. its TIME FOR AN UPDATE, but since my image server is down for maintenance there will be no working pics.
right, im borrowing a motor to stick in my car until my new engine is built, My mate has two spare B20A engines, one he bought from a guy that he had rebuilt, and the other one our of a prelude he just bought for parts. i dont know what one to use, the rebuilt one would be nice lol
Either way i want me car to be going by tomorrow so i can use it instead of this automatic b20a vigor im driving now that belongs to my mate, He will be able to have it back and fix it up to sell.
Ill put on some pics when im done
MAN its going to be so good to have my car back again :D:D:D:D:d i wanna go do it now just for the pleasure of driving it haha
well the good and the bad... good.. i got motor and box in the car last night, all went fine started mint, just when we thought my mates rebuilt b20a was good, we installed the radiator and found some fail
Water leakage between the head and the block
:slap:
thats a cack if i ever saw one esay fix though
i have reused a gasket i had lieing around, it seems to be working, good compression no smoking and it doesnt use any water. i drained out the milky oil, i think the oil was milky from all the water that went into the oil when i removed the head
now i have a new ploblem to fix, sump plug is fucked. some ass decided to overtighten the bolt and fail the thread. im fucked if i know what im going to do about it grrrr i dont want to change the sump!!
Fuck man. They installed the gasket upside down? How do you not notice that shit? Looks like a pretty obvious error to me. And yeah, that milky oil is due to the water in it. Don't run it if at all possible, it can eat up your bearings. Even a second oil change would be advised, because there was prolly still milky oil in the bearings after you changed it.
Glad its going though, can't wait to see your performance rebuild get going! What do you have left? Just missing a bearing and thrust washer?
yeah and a set of rings for the b16 pistons. wish someone copuld send me some of those for free lol
this mnotor has sorted tis shit out, swapped the milky oil and out new shit in and its clean, holds water and doesnt overheat anymore so looks like the head gasket swap was a winner, been driving it around today, Cant cain it cause i am unsure of wether the engine is run in yet, so anyways its going to get run in again k thx.
looool that's just plain stupid
When i get my motor built whats the best way to run it in guys??
After lots of research here's my opinion.
1) Do NOT use synthetic to start.
2) Use the same weight of oil you plan on running in the car.
3) Idle it for 15 minutes at 2,000RPM. (This breaks in bearings and cam)
4) Drive it normally (not hard but not like grandma) for the first 500-1000 miles or equivalent KM. (To seat rings)
5) Change the oil and call it a day.
6) Retorque the head and adjust the valves if you feel you need to.
I'm pretty much against the "race" break in. But that's just me.
thats a good start, Knew about the oil one. Ill use the standard oil grade from factory whatver that is lol
damn thats a long way to drive to seat rings dang lol
went to town today and experienced fail. the reused head gasket failed on me. HARD
all the oils left the sump and put itself in my radiator and made an ABSOLUTE FUCKING MESS. brown sludge everywehre!!!
So im going to pull the motor out and give it back to my mate, he will do what he wants with it, probably put a new head gasket on and put it in his ldue when he installs the turbo. Me? well im going to go pull out the other auto b20a in the white preldue he bought for parts, ill install that in my car and it will do until i have gotten my engine rebuilt,
FUCK the cunt that installed the head gasket upside down.
EDIT::::: 2013
The oil in the coolant was caused by the oil cooler on the back of the block. it had a crack in it and put full oil pressure into the radiator. The head gasket was fine after all (Y)
No doubt man. Fuck em. Good luck on the quick swap.
Yesterday me and my mate pulled a motor from a 2g lude he had bought and we installed in in my car and pulled out that failed rebuilt one of his. Seems to run mint, I took it for a cain last night thru some corners and the ol girl can still handle good, the B20A feels powerful. im so glad to have my car back running reliably again.
In other news, I have gotten my hands on an arm rest/brackets and also an under glove box tray. Mean
I now need some kind person from the USA to get me some cup holders as they are mega rare!
i dont think the glove box tray will fit a LHD they are quite shaped to RHD cars. Mines missing a bracket but i should be able to whip one up and install it.
im happy with my car with its temporary engine. the new motor is ready to be built now.
Im getting good fuel economy with the temporary engine, yes this thread is lacking pix
pics pics pics
Got my car legal today, went for a wof, as the sheet says it failed on the exhaust mounts cause some were off, low power steer fluid and a missing high stop lights in the rear window. also had a loud left rear wheel bearing. i fixed all that up and it passed. so shes legal for another 6 months with its temporary motor.
When i installed this temporary motor i had a spot of fail. snapped a head bold tab off the side of the intake flange and it took a piece of runner with it, so i have obtained another one
