The coupes and hatchbacks had dealer installed sunroofs but thats about it.Quote:
Originally posted by HostileJava
I'm not exactly sure what you mean, the moonroof looks flush with the roof and it has two buttons next to the power windows thingy to control it that looks factory. Are you sure the SE-i didn't come with them?
OPen the sunroof on the coupe. If you look at it when its open you will notice that there is a black outline around the edge of the opening. THat is part of the frame for the aftermarket sunroof. If it was original there would be no black frame and the sheetmetal would angle down around the whole where the rubber seal of the glass slides up and pushes up against
If you had a four door lxi you could tel te difference right away.
I found out that the coupes and hatchbacks didn't come with original sunroofs when I wanted to put the sunroof off a 4dr onto my hatch. The roofs are completly different.
