I see. Is there a simple, effective and cheap solution to this problem?Quote:
Yeah the GM 3.5 bar map sensor this is what im going to use on my setup. AEM sells this setup or you can find them online elsewhere and it still has the same 3 wire hookup. Im not sure if it will work the same since on the AEM EMS you have to scale the values a bit when you do this.
If you dont want to do that there is another method of check valves that seems to work fine as Justin used this on his car with over 20 PSI. This would be the cheapest method im guessing.
Do u only half read what I've talked about?Quote:
Originally Posted by SteveDX89
How can u possibly comment if u dont read?
'B20 (A)' is all over each thread Ive made.
Civvy
Why did you post that link? It serves no purpose for the B20A.Quote:
Originally Posted by Civvy
you could use a different map sensor, but youd have to run stand alone engine management because a GM map sensor no worky w/honda computer
