Those look good, i might be doing something similiar like that but i will keep a stock cluster just incase if the other one goes out. I like the stock guages...just the bouncing speedo needle looks weird.
I know I've said this several times before, but print them on vinyl, the stuff you use to print stickers out on the inkjet printers. After several warm cold cycles outside the paper will get moisture in it and start to puff or curl.
i hate how the bouncing speed needle looks...my friend saw it and was like are you going 25or 30....that is how bad it is.....ima search if on how to fix it.Quote:
Could be a loose or broken speedo cable. Mine was doing that when it wasn't tight in the speed sensor housing.Quote:
i tried doing that myself a couple of years ago. but i didnt like the way they looked in my car. didnt really match, so i still got my old black face gauges. i had thought about printing on photo paper myself, but never did it.
Ok, im not trying to jack the thread but i just need some help relating to the whole cluster thingy.
ok i want to change the lighting color of the gauge cluster when lit up at night. how do i go about to change the white lighting to say a blue lighting?
do i change the bulb? paint it? help is definately appreciated from chickensandwich and crew.:)
what people have done here is redo the whole lighting situation with LED's as well as used black lights and other shit. search, i would for ya but im lazy
