Did anyone ever try this?
Gio is supposed to, but he is dragging ass. ;)
I was giving this some thought, if the 88-89 lxi uses the same caliper as the teg, the rotors should be the same right?
If so, then what ever brake kit is available for the teg is theoretically available for the 88-89 lxi???
The rotors are the same diameter but the offsets are different.
In the front, basically yes. The 'teg rotors have a smaller offset, so to use them you would need to add some washers or something to space the calipers out from the knuckle. The difference should be approximately 7mm.
The rear is an entirely different story of course.
C|
