You dare to question the mighty brake lord? You shall be shot for heresy.:lol:Quote:
Originally Posted by sunofogun
Whats was the brands ? make of the rears. Some compunds might be real noisy and make the "Mack" truck sound when braking.
Also make sure the shoes are on the correct sides I believe one shoe is longer then the other atleast on most drum setups. its been a long time since I done my rear.
Originally Posted by Ls1-Inside
Part 1: Yes. I explained this a few days ago.
Part 2: Oh I forgot! You know MORE than Carroll Smith. Silly me. :bs:
Oh yeah! ANOTHER guy on these forums with more automotive knowledge and experience than Carroll Smith! Holy cow! This place is amazing! :bs:Quote:
Maybe I should buy a Tornado Gas saver. I've read some people who said they saved like 20mpg since they started using it! And maybe I should buy some of that spray on hair, I hear that works! Or maybe some of those dick enlarger pills too! I mean, after all, if people are sharing their 'non fictional recollections' of 'factual events' then it MUST be true.Quote:
Wait. Hold on a sec. One problem:
50% of the population is of below average intelligence. ie, Half of whatever you see is probably written by a MORON.
Originally Posted by Kelvin
apparantlly that article is a good read. i'll have to get the time to read it sometime.
i still wouldnt suggest cheapo rotors though poor casting, poor materialls, and subpar heat disapation. something a little better with a lifetime warranty like someone else suggested.
I have also experienced rotor warpage from rapid cooling bis flash tstorm several times in my life.
but everyones gotten off topic here. good discussion but wrong place. answer the poor guys question
Poor casting? Who cares. They're machined. That means they'll fit fine. As for 'heat dissapation.... I dunno, I really don't think it's something you're going to notice. In fact, if I had the money I'd use my gtech and do a 'rotor test' just to prove this once and for all, but again, pads are far, FAR more important than rotors.Quote:
Originally Posted by guaynabo89
Brake lord - :lol:Quote:
Originally Posted by LX-incredible
The brake lord must have been mad at me when I took my ASE test.
well most people dont want to have to swap out rotors to get them machined. To you and I it might not be a big deal, but there are most people who want their moneys worth without having to pay a mechanic to resurface the rotors. theyd rather just put em on an expect to get like 2-5 years of no problems.Quote:
it all comes back to the old saying "you get what you pay for" and sometimes when you pay cheap you get cheap. (not for every single case though) youd have to ask the original poster how he feels and what he expects out of his money.
Aha I just saw this, and I've read this article several months ago. I also understand the metallurgy behind iron and steel and know that temperatures below the Lower Critical Temperature (930 deg C) WILL NOT cause any more cementite to form. All of the cementite present in the material has already formed from the above Upper Critical Austenitic solution of Iron and Carbon, as the material cooled directly after the pour. Also, pad material will not influence the chemical make up of the cast iron rotor's surface. Also, Cementite WILL form evenly from Austenite (material heated above LCT) because it is coalescing directly from a solid solution.
In fact, heating below the LCT (like how brakes heat up) is commonly known as a process anneal, and when done evenly and cooled properly, is done to improve machinability, ductility and to remove stresses and strains.
What dost thy say to this me lord?Quote:
Originally Posted by guyhatesmycar
Thy says that technobabble sounds impressive, but ultimately one must have faith in way more experience/knowledgeable Carroll Smith. Though must remember that disbelievers are not famous for racing in lemans, or on first name basis with Carroll Shelby. Have faith in thy never-warped discs.Quote:
:bow:
This is not technobabble, it is the reality of basic metallurgy. I tried to put it in the simplest terms possible, in order to convey the fact that what they are saying is WRONG. The most basic properties of iron and carbon forbid it.
I decided not to pick apart the above statement like you have done to everyone who has responded to your posts. I read it and found that over half of it was , nevermind.Quote:
You have a lot to learn amigo, true you have brought to our attention a very interesting read, not written by you, and already posted here previously. But your communication style really does not reflect on you positively and frankly is a textbook demonstration of blissfull ignorance. If you can't see that by the responses you got then... well maybe you just read the half that quotes you.
Kelvin a lot of us here do enjoy a good debate so when you can come up with a stong enough pitchnet, bring it on. Leave the insulting tone and name calling in your shorts though. I am sure you more smarter than you appear to be, you enjoy bringing some compeling arguements to the table, but be advised you are addressing a diverse crowd here, some are just owners who do not even do their own work they are entheusists, some of us though have many years of experience in all areas...imports, domestic, fabrication, performance, paint and body, business, non automotive, duh brakes., education, medical, military, geez who do you think you are.talking to these people like you do.....I apologize for going off topic.
A few other things to check according to those symptoms. If you are using low profile tires make sure the beads got seated properly. Make sure the caliper mounting bracket is put on correctly, clean mating surfaces and slowly run down the bolts a little at a time so it goes on exactley straight and DO NOT BEND it, or the caliper will never hang streight again. On the rear , excessive clunking could the be backing plate worn out where the shoes slide, grease those places where the shoes contact the backing plate with a very very light dab of brake safe grease. You may need to replace holddown springs too. If you can get your hands on a infrared thermometer, you can make a few stops and measure the temps, if you have an excessive amount on one side you may have brake line or caliper sitcking issue.Quote:
See other thread.Quote:
Well I talked to the best mechanic at my shop and he is pretty sure im start ing to get play in my front hubs. This would explain why a complete brake job did not solve anything. First I will clean and scrub all mating surfaces and sliders, and machine the rotors off the car. I wish I had a dial indicator so I could check the hub runout, ohwell . If after this the problem is still there, I will go to the dealership to have the rotors cut on the car.( Because I do not feel like buying new hubs or pressing the bearings out!
you didnt replace your akels recently did you?
check the tourque on the hub nuts just in case. you never know could be something simplelike that.
Nope never taken the axle nuts off
Should show up if your rock the tire off the ground at 12 and 6 position.Quote:
I dont think our cars need the rotors turned on the car but you can give it a shot.
You can rig up a pointer to try and see if you have run out. A fine tip marker works if you can find a way to hold it steady.
:wtf: are you talking about?
Between this thread, your attitude, and the other thread, you've completely lost any and all credibility to me...
I honestly hope that others don't "Keep the Faith" and listen to what you preach because it is simply wrong, dated, misunderstood, and misrepresented by you. Carol Smith - were he still alive - would most certainly agree with the modern sciences on braking rotor and pad technology, and would undoubtedly accept breakthroughs in physics and metallurgy research as fact. You represent 30 year old material as if it were modern day fact. I'm sorry, but what Racers knew in the 70's is different from what they know today.
-Dan
Yep. That's why nobody other than accord enthusiasts refute his articles. His books are still sold, and not updated, because you weekend warriors know more than the thousands of engineers and racecar builders who've read his books.
Nope Kelvin - we just know more than you.Quote:
You're the only one misinterpreting the data.
Read 'em and weep.
-Dan
He agrees with me. So does Carroll Smith, and the following brake company websites:Quote:
Originally Posted by 86AccordLxi
http://www.raceshopper.com/tech.shtml#warped_rotors
"Warped rotors (in most instances) are caused by the brake pads being operated at temperatures outside of their specified range. When the pads get too hot the pad material actually melts and 'fuses' itself to the rotor surface and creates a 'bump' on the surface of the rotor. In most cases this is not noticeable to the naked eye. This creates an annoying vibration when the brakes are applied"
http://www.performanceoiltechnology....ingsystems.htm
"The problem with this diagnosis and repair procedure is that first of all is that brake rotors do not warp. The second problem is that replacing a brake rotor with a new brake rotor or machining the rotor on a bench lathe will only fix the problem temporary. The problem will almost always re-occur after a period of time, thus necessitating further repairs. Brake rotor disc thickness variation or excessive lateral runout, as well as drums that are out of round can cause vibrations and pulsations in the brake pedal and/or steering wheel. Brake lining material transfer onto the rotor can also have an effect on this as well. "
http://www.powerbrake.co.za/download..._01_judder.pdf
"Even the best quality discs money could buy would have developed the same brake judder. Here’s why.... As explained above, the disc was continually coming into contact with the pads at the point of maximum run-out first. If abrasive pads were being used this area of the disc would wear down quicker than the rest of the disc surface causing DTV, which is felt as an intrusive judder. If adhesive pads were being run then the pads would have deposited more material on the initial contact point (the area of max. run-out) than on the rest of the disc surface. Again this leads to DTV and brake judder.
"It gets worse! Once you have the development of DTV the surface of the disc will begin to heat unevenly. The high spots will get extremely hot compared to the rest of the disc. When the temperature around these high spots reaches 650 – 700°C. the cast iron in that area will change structurally and transform into a material called Cementite. Cementite is far harder than the cast iron of the unaffected parts of the disc and will therefore wear considerably less as the disc wears down with use.
Cementite also has very poor heat sink properties and will therefore continue to run extremely hot resulting in the rapid spread of the Cementite formation deeper and deeper into the disc. As a result the DTV will get progressively worse with time until it becomes literally unbearable to use the brakes. Depending on the pads used and the driving style of the vehicle owner this process could take 1000 – 6000 kilometers to develop and, NO, the initial run-out will not necessarily be felt by the driver. Hence the confusion and clinging to the concept of brake discs “warping”
Other than that, yep, nobody agrees with me. I'm okay with that. It seperates the cream from the curds.
