wouldnt the TEIN be a full coilover and the dropzones springs? if so then they are different.
im thinkin that regardless of whether they r springs or coilovers, if they r made for the civic, they will all fit the civic. and if one set of civic springs fits our cars, then shouldnt they all, regardless of who makes them and if they r just springs or full coilovers?
i dunno, just thinking logically. i could be wrong
TEIN does not make coilover sleeves. they have springs and full coilovers, and are far superior than any sleeve you can buy.
as far as springs fitting vs. coilovers, you are gonna have to make sure what the heights are. if the civic spring is taller than the accord spring, a civic lowering spring on an accord might not drop as much as you want, and if they are shorter you might get too much drop. and also, the accord is a heavier car than the civic. if the springs cant correctly support the weight of the car your ride will suck ass.
so. Tein civic app= no go?
so im kinda confused lol ef civic coilovers will fit but a set of tien ef coilovers wont
ive noticed that ksport makes a nice set but ive heard alot of bad things about ksport and d2 when it comes to reliabilty and durability thats the only reason im iffy on them
status report...got a set of Tein lowering springs from my buddy. they were on his 97 Civic hatch shocks. The springs fit on the Accord shocks, but the Civic shocks DO NOT fit in the Accord. They are too long/tall. Also, I had to make a "hat" for the rears, because the spring was about the same size as the hole at the top of the shock, so I noticed the spring kept going up into there over some big bumps, and ended up crooked. I made a custom "hat" to keep the spring straight.
Next up is a set of Tokico performance shocks. I found a new set for $260 shipped. Anyone know of any that are cheaper?
They're about that much on eBay, maybe a little cheaper. Unless you're talking about Illuminas.
you can modifier the civic struts to work.. i know a few members on here have done it.. 87roach is running skunk 2 ones for a civic i believe , and i "think" mushroom_toy has civic shocks as well
