i got a coil from a motorcycle you think thats works ? and if it has two plugs on the coil should there be one pos and one neg.
i got a strait pipe exaust you think i would get nice flame or any at all?
midnight: yes I would think that would work nicely!
i am still confused on what i need to make my car a flamer......:-)
help me out.
If anyone lives through this, I'd like to have a how-to
Im trying it after skool. If youd dont hear from me before midnight, youll know what happened ( :flame: <ME> :burn: )
Fuck. I got all the parts, they all werk.
BUT. Ive been trying to drill a hole in my exhaust tip, but it wont go through!!! I got 1 cm hole.... but the drill bit melted... HELP!!!!
You need a carbide or titanium drill bit to go thru steel. Any parts store should have one.($2)
I found ONE in my dads tool box, it opened it up to about 1/4 inch or so
Im thinking it needs to be 9/16?
Ill guy buy a 1/2 and a 9/16
Stew: you are god
:bow: <Stew>
yeah 9/16" sounds right for a spark plug... take some pics when you have it all together.Quote:
Stew: you are god
:bow: <Stew>
lol @ god.... i'm not a god just a guy thats been cutting his knuckles on cars and spending every last cent on em for way too long!
I Got the frickin plug in yey!
Alls I gotsa do now is wire it.
Stew: On the coil, does it spark when it gets voltage?
How do i wire this? + straight to the battery, - to the batter with a switch on it? So when i flick the swicth, the circuit is complete, and causes it to spark? :-/ Do i put the pos on the chassis..., help
Yes the coil sparks when it gets voltage!Quote:
This is where the relay comes into play. You ar not putting a hot circuit straight fom the battery to the coil and back to a switch, this is pretty dangerous.
Instead you use a standard 5 point relay with 12V battery power and a chassis ground, and from that relay to the coil and then the last 2 points go to a switch.
Think of it like this on each relay point:
- 12V source
- Ground
- Power to coil
- Pos to toggle switch
- Neg to toggle switch
When you flip the switch the relay allows 12V past it and to the coil.
http://www.geocities.com/icaruscode/flamer1.txt
http://www.geocities.com/icaruscode/flamer2.txt
Sorry bout the water mark... All I gotta do is wire the switch :p
Please dont make fun of my muffler :( hehe
Allright Stew, I gotsa problem.
Im getting no spark. Heres how i tried it: Pos is grounded to heat shield. I ran a wire from the neg to the neg on the bat. I know the coil werks, tested it in my car, i checked the sparkplug wire, its fine, and the sparkplug is brand new, gapped to about 50.
Any suggestions?
http://members.shaw.ca/mustang/pics/flamethrower.JPG
youve heatshild is NOT a ground!
I would also recomend taking power off a switched power source not the battery so that it can flip on by accident when the car is shut off (your cigaret lighter should do the job).
Ok, got the biatch to spark. But no ignition. Regapped it to 60, sparks, but no ignition, even when i rev to 5K
stew? help?! hehehe
Yea, im going to finish the wiring job when i get it to ignite...
could i be getting a weak spark cause its not grounded properly, thereby casuing it not to ignite?
Prolly the exhaust
with a cat and a stock muffler not much unburned fuel is going to escape.
time for a new exhaust system sans cat.
Me thinks we were on at the same time :-p
What happens if i plug up the other exhaust tip? will the exhaust be more concentrated in the other tip?
stupid question, but couldnt you use a starter for a gas grill?
it may not have enough spark... I used to shock my friends with those... and watch their muscles spazzz!
Its wednesday, and im still not getting any flames :(
Im getting a spark, a very large one, i dont know what else to do.. maybe ill get a new muffler with my next paycheck...
Any ideas?
Take your cat off and put a strait pipe onQuote:
Any ideas?
maybe you're just not running rich enough??
