Did you make sure your wheels were straight when u put the steering wheel on?
I've had the same problem. Did you have this problem with your old steering wheel?
If your wheels are centered, I think you might need an alignment.
I took my stock wheels off and put the Prelude wheel on, and then back to stock when it was rubbing and now I have the same issue. I know I need an alignment and the ball joints are bad. I'm gonna try and remount the stock wheel once the weather is warm enough to sit outside and do it. I think I just mounted it a little cockeyed.
And when "trimming" the Prelude wheel so it doesn't rub, how should I do that? Just use a file and file it down?
