You can run 93 octain with up to 10.7 compression but that would be the limit. After that you would need some addative. Now this is on a n/a engine. So if you boost with 10.5 im sure u would need some good fuel with some good additives (no cheap stuff!!!) and ob1 so you can control your timing because you would have to retard some under boost and a good fuel management! If im wrong will some one on here correct me plz?
