Re: Bad oil leak under intake manifold
Lead Foot
K. So just did a compression check. 180, 150, 150.... 30. Seems like I have a bigger issue. :(
that doesn't mean you have bad rings, you need to do a wet compression check, that means put a teaspoon of oil in the bad cylinder, and do the test again, if it doesn't change,the issue is in the head, you could have a burned valve or a crack in the head etc, the two middle ones both being low also could indicate this, possibly a crack between cylinders in the head.
That's more where I was leaning. I would think all the rings would be bad. The other cylinders have good compression. Hole in the piston? Maybe the idiot before me dropped a bolt in the cylinder? But I would think it would smoke more just cruising around, not only when climbing hills... What about an extremely bad valve guide or seal? I honestly didn't examin the valves when we changed the gasket. maybe a broken valve spring and a dropped valve?...
Well a dropped valve would explain compression but not the oil huh? Also using a Gauge with the rubber cone and not a thread in. So middle two could just not have sealed all the way on the gauge. Chances on only 1 valve being burnt? I thought they all would burn, just like rings?
Btw. The dead cylinder is closest to the passenger side. Spark plug was deep brown but not wet. Others were quite lighter.
Lead Foot
sure one valve could be cracked, or burned, if you had something like a cracked valve guide, or a crack in the head that also would explain the oil, don't condemn the rest of the engine until you know for sure
