the clip lays perpedicular to the cable.... ...put the cable in, slide up the rubber cover. Look at the top of the speed sensor and where the cable goes into it. You'll notice a small "cut" in the neck of it. Just slide that clip around that neck and into that little "cut". You'll notice that the clip has one side that's a little flatter then the other. That's the side that lays into that cut. If the cable is in all the way, that cut will line perfectly up with teh groove in the cable, hence the reason for the clip, and it's ability to hold the cable put. To make sure that you've got it in right, give the cable a little tug.. If it comes out, try again, if it's "stuck" then by gollie you've got it!...
>>>I'll see if I can break out some paint skills and draw something up for you in a few....
BAM... ...m/s paint at work.... ...any Q's feel free to ask...
thanx a lot Mark i fixed today !
BTW nice drawing !
MIKE
anytime.. ...anything else you need me to whip up in paint for ya'?:smokin: LOL..
