Re: cfm recommendation & cid to liter translator
ok thanks a20a1 sorry if i was annoying u with pms im just trying to put my stuff to gether as quick as i can(gota get back to work so i can spend more money) and u have alot of knowledge that i dont.
Re: Custom, Performance Carb Intake Manifolds ( 2bbl / 4bbl )
Hey Shepherd79 what was the alumaloy like soldering stick you found that was better than alumaloy?
I need to finish the dividing wall in my manifold, that way I keep power in the low end by having a smaller plenum on each side, dividing the carb, and keeping the runners the small diameter that they are.
I really want this manifold to look nice, with black textured BBQ like paint and brass barbed vacuum fittings and colored brake fluid lines converted to vacuum hard lines for PCV, Distributor, and Brake Booster Vacuum.
At least I can finish it all up and sell this manifold and hopefully the header too, I don't think I can find another 3G and do the 4bbl conversion any time soon.
i got it from this webpage.
https://weldingsupply.securesites.co...ogs.pl?SIGNOUT
the stuff called WELCO 52. if you do a search for it, it is the first thing that comes up on that page.
make sure you get your hands on this http://www.bernzomatic.com/bernzomat...rnzoProd100044
or at least mapp torch, it burns hotter than propane.
this product is easy to work with.
just make sure you clean the area very good, ruff it up, and heat it up.
Thank you . :)
awe I searched but it says it's for galvanized steel? Was that what you used it for or did I search wrong?
EDIT: nevermind I found it :)
So I can use straight mapp? I'd like not to mix gas if all possible.
Interesting experience...
http://www.bob2000.com/carb.htm
Scroll down to the first paragraph under "BASIC THEORY"
He also confirms for me that with vacuum secondaries, big carbs could be made to open just right for the engine so size isn't that much of an issue.
All you carb guys can appreciate just how big theses secondaries are
I just love the person who designed the Q-Jet... just as crazy as I am. :)
Dual throttle bodies anyone?
http://i23.photobucket.com/albums/b3...s_of_Helll.jpg
good lord that is huge.
i hope you can tune that SOB.
I will see how big the chokes and venturies are when I get the carb... then I'll get a better idea about what to do.
