Originally Posted by rjudgey
Apart from the oveheated oil looks like a perfectly rebuildable engine, honing marks still on bores so has done little mileage and had been serviced properly for most of it's early life. I'm guessing it's probably done between 80-100k miles only. The biggest thing to worry about is wear on the camshaft bearings on the head if there good everything else is easily fixable just get the bare head and block xrayed to check for cracks before you start machining it and buying parts. Block looks pretty clean not a lot of rust must have lived in a dry area most it's life. Good find anyways what you doing about gearbox?
