it took me fucking forever to get the bushings the right size. but thats cuz i didnt have a dremel.
^^ explain.
I took the brackets for the vigor bar and redrilled the bolt holes so that they would fit the accord chassis. That allowed me to reuse the bushings from the vigor.
thats really fucking simple. why didnt i think of that?
shut up fagots. lol makin me look bad.
rear sway bar FTW
Alrighty! Just back from the junkyard and found a 92' vigor with its rear sway bar. I kinda failed at preparation and only brought crescent wrenches cuz I thought that they were just bolts and nuts. EXCEPT most are hard to reach... and so I can't get any torque on them, but I borrowed a socket from the shop and got everything.
Here's my question: I got everything except the two brackets more towards the middle of the car. they had like 3 fatty bolts each that I couldn't get to the other side of them without dismantling more. Did I need those brackets? each had one bolt holding onto the sway bar.
I'm going to make it work somehow, just need some insight lol.
crap, So its better to take the brackets off the vigor and use those instead of the accord ones? That's what it sounds like most people did. Looks like i'll make another run into the junkyard and grab those.
And then i'll replace the accord stock ones with the vigors? so it'll fit the bushings correct? I know I can assemble the rest, just gotta get my car elevated a bit. I've got a drill and a bunch of bits so I can redrill the holes.
yes. Since you have a DX you should just grab the vigor ones since your car doesn't have a rear sway bar. Meaning you have no accord brackets.
you just redrill the holes in the vigor brackets so they line up with the holes on the accord chassis. There's only two holes on the accord though, and 3 on the vigor brackets so one of the holes won't line up with anything.
Bleh, I went back the junkyard and got the brackets no prob. Figured out where to drill and went ahead mount them in the correct 2 spots available. But its interferring with the axle? Or something.... Not enough room between the bracket and the frame/axle. Sooo annoying.... Here's some crappy cell phone pics of what I mean. I tried bending back the brackets a bit but they are seriously tough. (prolly a good thing lol) Any suggestions?
http://i65.photobucket.com/albums/h2...03-09_1445.jpg
http://i65.photobucket.com/albums/h2...03-09_1446.jpg
do they rub when the car is flat on the ground or only when it's jacked up? I remember my sway bar rubbed when I jacked the car up, so I thought it didn't fit at first.
Yeah it was when the back was jacked up. Will it fit if its on the ground? Ugh... That'll be fun to get too...
yep no problem maing.
yeah that rear sway bar will help alot
Holy jumpin monkeys! Yeah its defintiely a night and day difference over NO sway bar. LOL
I got it done after ALOT of modifying the brackets. One side fit fine after redrilling the holes but the other wasn't... Like a mutant or something lol, after an hour or two JUST for that bracket I got it to finally hold everything. and then I bolted everything back up.
Its sexy how it handles now; except on the right side, the bar is right next to my exhaust pipe and on my bumpy gravel driveway it makes noise as it bumps against it. (going 60 on the road its fine though) whatev. I guess I'll call a muffler place and see if they can just re-pipe that one little section before the muffler as to not hit the sway bar. Other than that she's lookin good. ^^
I would post some pics but i'm too lazy to upload to photobucket rite now...
yup...good stuff
i painted my sway bar silver :rice:
x2 i agree ^^ wannabe st lol
