Originally Posted by ghettogeddy
I think that is Malaysian money. When I calculated it once I thought it came out to $1200 or something like that.
i found this link on there contacts lolQuote:
Originally Posted by Legend_master
http://www.kfxperformance.com/
legend your car is truly beautiful, i wish i had it.
Thanks dude :) .Quote:
Originally Posted by ahmad89
$824 dollars to be exact for the basic non adjustable shocks with coilover springs and height adjustments.
Then they have two way adjustable shocks as well, optional external canisters, and racing mount tops.
Add these prices to the above basic figure:
Canisters add $117 for front and $117 for rears
Adjustable damping shocks add $235
Pivot top mounts front add $235
Pivot top mounts rear add $176
Helper springs Front $30
Helper springs Rear $30
They have plenty of dealers world wide and are re-buildable also seem to get good reviews as well. Got to be better than stock KYB or TOKICO with lowering springs!!!
Adjustable topmounts are useless though with our suspension type :) So it makes you wonder why they list them.. it's obvious that they didnt put too much effort into the R&D.
It's not for adjustment it's to reduce slack as stock shocks have huge rubber bits and move around alot when working.
According to their website their top mounts are intended for adjustability as far as I remember? If not then cool. But if the stockers leaves slack it's because they are worn.
IF getting your stock top mounts are as hard and expensive as a 2G lude then the Hot bits Top mounts are a bargain and won't go rusty as there ally!!
They just talk about the top mounts in a generic term as most of them are adjustable but for ones like yours and 2G lude there's no point as the suspension needs to be adjusted to change camber not the shock.
