nice progress. your B20A will be jealous to see that a20 in there lol
good work there :) jam a bolt or something down the timing inspection hole onto the flywheel or pull the starter out & put a bolt in there somewhere to lock the crank in place
great progress!
Well today I have done alot.. first of build me a shack, than moved engine there, cleaned engine as good as I cud, changed timing belt, changed clutch and dropped engine in the black accord... was out there 10hours.
The story goes like that. Guy who I lend engine lift wants it back tomorrow or lats say today already. So I stressed it to get things done, at least drop engine in the car. and its poring rain today, so had to improvise a lill bit. So I build me a shack of some sort, but it worked great hehe.. Than it all begun, timing belt was a bit of a problem, crank pulley was so stubborn but eventually I got it off.. Than to the clutch, took g.box off and the rest (I have refurbished flywheel, but when I saw mine it was smooth like glass so I leaved alone)
To tell you guys, that washing with teeth brush is great and it works, and you get to most unbelievable places but it is time consuming ordeal.. Well I have some more pic whore here..
http://i91.photobucket.com/albums/k3...g?t=1245381178
http://i91.photobucket.com/albums/k3...g?t=1245381229
http://i91.photobucket.com/albums/k3...g?t=1245381254
Who said my engine bay was dirty?? lol not anymore its not, got it cleaned yesterday but it was to dark to take picks so I took those today.
...before...
http://i91.photobucket.com/albums/k3...g?t=1245381466
...after...
http://i91.photobucket.com/albums/k3...g?t=1245381265
http://i91.photobucket.com/albums/k3...g?t=1245381347
http://i91.photobucket.com/albums/k3...g?t=1245381380
And finally, the famous A20 is inside.
http://i91.photobucket.com/albums/k3...g?t=1245381395
http://i91.photobucket.com/albums/k3...g?t=1245381510
I sud have taken more picks but I had no time and greasy fingers..
Thats about it, Now all I have to do is wire it and connect all hoses and its done.
damn Tom, that's dedication right there. Congrats on even getting this far. That engine bay looks mint. What did you end up using to get it that clean?
Thanks Mark, I tried to be on top of things today. my back gona pay for that but I dont care right now.
I first used pink stuff, SilitBang I believe, but that didnt work so great, so I dropped that Idea and used paint thinner, I used spray bottle I had left, fill it up and toot brush magic and one old sweater in files. 2 hours later it looked like that. and Used Silicone in spray box for hoses and wires.
mice job man cant wait to see her running :) reminds me of the time i swapped my b20 for a a20a2
Wow, all that work for an A20, huh?
any more progress
No not more, but it coming soon. I wait for good weather. it been raining for 3 weeks now. and I got sick.
only connecting and wiring thats left, and all new fluids. Gas tank swap. short shift swap, hood swap (paint black first), maybe trunk lid and 4G rear sway bar.
This is what is nearest plans... so keep watching :D
Ok I'm done with the swap, now. I'm done with wiring, but the engine just want crank at all, the lights come on, and PGM-FI light comes and all, but engine just standing still.
I had one fail, It started to smoke from wire that coes from dizzy to that small fuse of some sort. I turned on, checked, found where the problem was and tryed again but no life from it..
What it cud be?
EDIT: here is wire that started to smoke
http://i91.photobucket.com/albums/k3...1020070061.jpg
this is what I did :(
http://i91.photobucket.com/albums/k3...Bilde004-4.jpg
Something is wrong.
This is a device to cancel parasites in the distributor signal.
If the car won't crank, I would check all the grounds
Is the ground by the thermostat properly attached?
Can you sign in AIM? Im there now. Thanks Carot
aim:GoChat?RoomName=ThirdGenerationAccord <-- here is the link, me and Mark are here
No one watch this threat I bet, but I write it down anyway.
I got engine started now, everything works, but it just want start from ignition key. Dont know what the problem is. I changed wire lom from other car, still nothing.
I have a Q. I had to cut ground wire to thermostat, because original B20 was to short. I didnt soldered it I just connected it and insulated with el.tape. cud it be a cause of my problem?
your try swaping the ign switch from the other accord? if that not it run a new wire from the ign to the starter
but i must say good progresse man! that engine bay look great!
Good that you got it started at least, hope you find what's wrong. Maybe it's the body of the car that's pissed about having an A20 stuffed into it? ;)
I thought about that lol, tried to sweet talk to it but she refuse to.
woa nice man
Updates :D
Today I done so far.
*Changed gear leaver to short shift. I had in my other car, I have welded it a while ago, shortened in 2 places. under ball and at leaver it self.
*Changed engine oil
*Changed oil filter
*Oil in Gearbox, used genuine Honda MTF3 oil, bout from local Honda shop.
*Assembled drive train
and I guess its time for some picks
http://i91.photobucket.com/albums/k3...Bilde002-1.jpg
http://i91.photobucket.com/albums/k3...Bilde001-1.jpg
http://i91.photobucket.com/albums/k3...Bilde004-1.jpg
http://i91.photobucket.com/albums/k3...Bilde005-2.jpg
and for those who never seen me.
http://i91.photobucket.com/albums/k3...Bilde007-2.jpg
its getting kinda dark so picks are not at their best. shitty phone camera you know...
take a bath you dirty bastard. ...and wash that shirt. haha, j/k.
So what's the deal Tom? You get her running or what?
lol....i was going ot say LOL....yeah is she running yet bro
Mark, I'm tired to shover every time I tern a wrench lol and those clothes goes to trash after I'm done with it.
Today is another day so I'm out working again.
Randon she dos not running yet, but starts. Not with the key, so I neither need to change igniter and wiring to it or run direct wire from key to starter and see if this will help.
