Re: Diamond Pistons Specs
cant you just send in a stock piston and have them make a forged piston set off of it?
Yeah they will need a stock piston regardless of what you do. But since you are then getting a 'custom' piston it is worth it to do the little tweaks that make it better.
such as 21mm pin so you can take your pick of LS rods, changing the position of the rings (help prevent blowing up ringlands - not sure on the details of this one, but I know it happened on my set) etc etc...
But yes I'm sure they could just clone a stock piston, though I am not sure why you would want to do that.
Seriously I would just call them up and pick their brain, they are super helpful and will probably have ideas for you if you just ask them what are some of the common tweaks or upgrades.
