MessyHonda
we share a similar story. My mom bought one new back in 1988. it was my first car but she had an automatic carb. I bought mine right out of high school 10 years ago and now im proud to say its one of the fastest accords on the site. glad to see other people working on our cars. like i say old accords just get faster.
Yes sir. labor of love
4 Attachment(s)
More parts inn oil catch can setup. Block plug and transmission installed;)
Is that plug off the shelf? for a B or D series perhaps?
knifemind
D series block plug from go-Auto Works. You have to cut off the first o-ring section. And use a fatter bigger o-ring
1 Attachment(s)
Arp head studs installed. Getting closer
Ayeee glad someone else did the block plug also.
Tdurr
Yes sir it's a must-have clears up a lot of space back there for other things like your engine oil cooler sandwich plate and turbo oil feed lines
yupppp. Im still suprised nobody did that before me(at least that i was aware of) it makes everything so much nicer. did you cut the return off of the oil pan?
Tdurr
Not yet wasn't 100% sure what to do with it. cut it plug it ?
I cut it off then had my welder weld the hole shut.
Tdurr
Cool man thanks for the info
3 Attachment(s)
Oil pump O-rings replaced and more parts inn passenger side CV axle ,lower control arm and timing tensioner pulley
3 Attachment(s)
Turbo oil feed fittings and line installed
1 Attachment(s)
More parts extended intake manifold studs and crankshaft oil seal
Hell yea extended intake studs!
Tdurr
Yes sir. I'm trying to get it right this time
4 Attachment(s)
Water pump, oil pump, belt tensioner, alternator front lower ball joints installed. EGR valve removed plugged. And I was only able to find a distributor piece from a head from a carbureted model. Which only has one ear instead of two .don't know if it's going to be compatible with the OBD1 distributor adapter plate
1 Attachment(s)
Thermal throttle body gasket installed with extended stainless studs
Tdurr
That a oem b16 intake?
Stock a20
1 Attachment(s)
All brittle and broken connections repaired and retaped wire harness
1 Attachment(s)
Radiator hoses dressed up
Shane86
best thing you can do especially if you get rid of useless wires
Tdurr
Yes sir and I like to get rid of majority of the black box components as I can
2 Attachment(s)
New intake and exhaust valves. Now if I can find some exhaust valve spring retainers I might be able to put the head back together someday
