Re: Winter Project *Lots of pics*
No, No more pictures what you see is what you get! Everything is in decent shape... No I didn't grab the rear disk brakes .. I want to SO bad but I don't have the time or $$ right now....
Yes April 5th! I can't wait!! it's won't be painted but i'll have everythign else done! (except sound system)
Hey All!
First off THANK YOU for the help 87roach.
We made some more progress this weekend, Got the upper half of the intake manifold installed as well as the fuel rail, injectors and separately I installed the ECU (clicked it into the harness LOL).
I'm off work early today so I'll be installing the Alternator and Serpentine belt.
Good stuff. You guys have a nice group of 3g's in the kelowna area... Hope you get the car back on the road soon.
Hey All :-) Another update! (I get to do lots of these recently!)
I have pictures but I got a new cam and need to Grab the data cable. I'll update here later.
Yesterday I installed the Alternator, Power steering pump, each corresponding belt, Motor Engine Harness. I gave the motor a good clean as well.
At this point there is nothing left to install on the block!! (except Tranny).
http://geminiwebhosting.ca/images2/DSCI0004s.JPG
http://geminiwebhosting.ca/images2/DSCI0005s.JPG
http://geminiwebhosting.ca/images2/DSCI0006s.JPG
http://geminiwebhosting.ca/images2/DSCI0007s.JPG
http://geminiwebhosting.ca/images2/DSCI0008s.JPG
I moved my car out of my shop for the first time in 8 months! Wow was that ever a circus! My shop isn't big enough to move the car around properly to I literally had to get it to the point that I couldn't move it anymore then used a floor jack to shimmy the ass-end sideways like three times... it took like an hour lol
BEFORE:
http://geminiwebhosting.ca/images2/DSCI0010s.JPG
I did the 'ol spring clean in the shop today.. again... it's amazing how many duplicates (and triplicates) of parts i have lol.
AFTER!!
http://geminiwebhosting.ca/images2/DSCI0011s.JPG
I also took an air hose and wet cloth to my car to get the 8 months of body work dust out of it... that also took more then an hour.
So now it's on to the final touches in the engine bay, getting my fuse box and the motor mounts installed etc. I have the wiring harness strung and mostly connected as well.
And one just because I felt like it:
http://geminiwebhosting.ca/images2/DSCI0012s.JPG
statistically, your car is SHWEET!!! keep it up man, it's like new!
Hey man, don't give up like I did. Take your time. If I didn't have a family to take care of, I would have kept going. I'm waiting patiently to see you car get finished!
Bump for updated pics above.
SWEET! can't wait to see a vid of this runing!!!
Hey all :-)
I keep finding that everything I put together needs one part I can't find so I end up going to the junkyard almost daily.. oh well...
I got shift linkage from the junker today as I was missing it lol... I installed my short shifter today :-) Here's some before and after:
Before:
http://geminiwebhosting.ca/images2/DSCI0007ss.JPG
http://geminiwebhosting.ca/images2/DSCI0009ss.JPG
After:
http://geminiwebhosting.ca/images2/DSCI0010ss.JPG
http://geminiwebhosting.ca/images2/DSC10011ss.JPG
I'll need to adjust it once everything is installed.... I ran into an issue with my tranny today... the spring that holds the throw-out bearing is broken so i'll need to pull a tranny at the junkyard just for that one small piece. I also need to re-install my Gas tank... I found out I'm missing the straps that hold it so again it's a trip to the junkyard.... I also found out that I was a dumb ass and cut my fuel lines coming off the tank, at least it's easy to get new ones when I drop the tank tomorrow.
What did you use for sound damper? Looks like aspace shuttle in there!
Hey I'm home quickly and i wanted to drop "a before i started anything picture" here it is:
http://geminiwebhosting.ca/images2/newcar%201.jpg
I got the shift linkage bushings switched over today.... A long long time ago I bought them.... Post 194 I think :) ...
As per the norm here is the before and after.... I couldn't find these anwhere on the internet again...
Before:
http://geminiwebhosting.ca/images2/DSCI00011s.JPG
http://geminiwebhosting.ca/images2/DSCI00012s.JPG
After:
http://geminiwebhosting.ca/images2/DSCI000113s.JPG
http://geminiwebhosting.ca/images2/DSCI000411s.JPG
I got other work done too but mainly it was getting odds and ends from the junk yard, such as the throw out bearing spring, the straps to hold the gas tank (which suck) and the gas lines off the tank.
I can now mount the tranny to the engine! Once that's complete there will be nothing left to put on (i think) :-)
I'm getting closer............
Looking really good man, nice to see progress! I got a new job so I don't know how available I will be but I will try and get some time in, let me know if your going to still going to try and fire up on sat.
yeah I want to... I having doubts i'll make it but I'm trying real hard!
More Progress!
Tranny on :-) Starter on :-)
http://geminiwebhosting.ca/images2/DSCI00200s.JPG
http://geminiwebhosting.ca/images2/DSCI00211s.JPG
Justin86's bar's installed (not all of them just the lower set) :-) I also installed all three motor mounts and the shift linkage:
http://geminiwebhosting.ca/images2/DSCI00188s.JPG
more progress later :-) I might drop in the motor in tonight if i get ambitious :-)
Lookin good... good to see more progress being made too.
Going Going Going....
http://geminiwebhosting.ca/images2/DSCI0001aas.JPG
YES YES YES!
http://geminiwebhosting.ca/images2/DSCI0002aas.JPG
It went in like butter! Lots of room all around the motor... I know the valve cover sucks I have a new one just havn't installed it yet. I THINK I can get this started tomorrow!!!!!
Looking good! But, why is the picture on top flipped left to right?
ahh yes, dormant projects coming alive ~~~~~
looking good
Can't wait to see the whole car painted!
redaztec
right?
he was trying to convert it into a k20...
lol yeah I was in a hurry because I was so excited about actually having the engine in...and now i'm too lazy to fix it lol.. I worked all day today from like 830 am to now 10 pm on that fricken car .... I am going ahead as planned Tomorrow April 5th I will attempt to start my car.... I am SO crossing my fingers... Interestingly I learned that we can run our own fuel lines where ever we want I bought a 25 ft length of high pressure fuel injection hose (pricey) but now I get to relocate my filter to the tank :-) (like carbed cars) ... anyway this is how it's sitting now:
http://geminiwebhosting.ca/images2/DSCI0002zzs.JPG
I had to take off the header as there is a small hole that needs some welding.
Whats with the paint on the tranny?
thats great, i bet you're having alot of fun putting her together :)
The tranny looks like crap but I can change that later on :-) Thanks for all your support.
Looking good! You have to get a video of the first start up!
Yes, I have a couple coolant lines and the cv's and then I can start it up, Tonight 5:30pm :-) Oh I put a new valve cover on and it looks great ;-) I will get a movie of it first starting!
whats ur orange called? Sexy ass color, I wanna do my ride up with orange/white two tone. An orange like that would require the pearly white of the escalade but damn, nice!
I'm kind of excited to see a video of it running, after following this thread for so long.
Yoooooooooooooooooo what's going on up there, is that thing running?????
I'm DONE. I think, I'm off to hook up the battery now... VIDEO to follow if I Have good results... everyone WISH ME LUCK.
Good luck, man! I can't wait to see and hear it running!
Damn, Electrical issues, No worries i'll poke and prod tomorrow :-P
stink :( i was loking fowrad to the video
A18A
I'm just posting a pic of the new valve cover and finished engine bay :-)
http://geminiwebhosting.ca/images2/DSCI000c6s.JPG
I'll try a couple things to the accord tomorrow I really needed a day off from it.
Wow, new valve cover was a very nice touch, hope you wont have too much troubles to get it to run.
:cheers: dam that looks good weres our vid man :confused:
Well I got it to turned over yesterday but for some reason I've got no power to the pump, I'll give it another shot today and figure out what's wrong
what you wired the pump backwards?
Gemini2003
Check the main relay and the ground wire near the injectors and/or thermostat in the engine bay. The main relay grounds there. This is what drives the pump.
A cold air intake would lick titties in that engine bay!
I actually had one but it got stolen out of my shop :-( I have suspicions as always but no proof *sigh* So I am using this cheesy Weapon R filter and a piece of aluminum that I had in my shop... I will be buying a new cold air intake and will be routing it down thru where the battery is now. The battery will be relocated to the trunk in the near future.
I checked the main relay, replaced it and now I have power to the pump and ECU when I turn on the car, ECU is now flashing 13 red flashes indicating: BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor. It's missing lol (as this happens to little sensors over a year). I looked in the Hanes manual and it's supposed to be in the trunk... the thing is I looked in the trunk and couldn't find it in my working accord... but I'm not surprised it's a different model. I will be going to the junk yard first thing in the morning.
*Edit - I just looked in the online manual (http://www.pauldesign.ru/honda/shopmanual.html) it says it's behind the glovebox... I'll take look tomorrow*
On that note if anyone knows if it's not in the trunk please let me know.
All in all the mistakes I've had to fix are due to inexperience and next time I will be sure to do things a little differently to avoid this same issue.
Justin86, Your rear strut tower brace didn't work quite right... I made it fit, We will see if it effects my alignment... (no offense or anything I know things aren't always perfect)
http://geminiwebhosting.ca/images2/DSCI0003cs.JPG
redaztec
To confuse the HELL out of me!! I spent like 3 minutes looking at it trying to figure out how the header was in front and the tranny was on the right!!
THANKS CAROTMAN!
After fixing a small fuel issue i got it STARTED!
Video a little later. (it's a short one)
WHOO HOO
Awesome! congrats... must feel really good!. Can;t wait to see the video.
Glad to hear it's running!
OK Sorry about the audio, Bad camera and open down pipe don't mix.....
BUT...
Here's the Video :-)
I'll get a better video with my buddies digital video recorder later :-)
i bet that felt good when you started it :D
That is just AWESOME man!! Finally got the car going, I'd say the hardest part is done, now you just gotta get the rest installed. Can't wait to stop by! Keep up the good work.
w000t Congrats man! She runs!
Looking forward to the finished project
you should drive it how it is :)
I want to, but I need to take care of like 5 things before I can tho!
man i wish i had a rebuilt engine
Hey guys! A little update... I'm doing all the small things now to make it road worthy... I got the last few odds and ends today and i only have a few things left to do... no pictures as it's very boring stuff lol work has been eating up all my time :-( But it's gunna be worth it... Thanks again for stoppin by
was wonderin if you were still around workin on that guy, good work... lookin forward to seeing it finished... going to have to have a mini meet once mine, yours, 87roach are done.
Heck yea man, although "done" might not be the right word haha. Looking forward to a meet and checking everyones cars out, get some work done mike! :P
life is stupid busy right now..... I will be working on it again soon tune it up sometime this week
Sorry for the no updates BUT...
I finally re-installed my gastank today... it was interesting running my new brake lines..i did get them up out of the way anyway. I'm getting the windshield re-installed tomorrow and then all that's left (to get it rolling) is the drivers seat and shiftlinkange :-)
I am taking all the orange panels from my other car and putting them on this one until i get all the body work done.... it's cheating but i don't care at this poitn i just want it on the road. I may have it insured next weekend :-)
Gemini2003
haha i know how you feel there. good luck
YES!! My Windshield is installed, pretty easy to do, I"ll be doing it myself next time :-P
I have like two major things left... Shift linkage and driver seat and then
TEST DRIVE!
IT LIVES! WHOO HOO!!
I only moved about 30 ft BUT i did it! The car moved! WHOO HOO
congratulations! i'm jealous mine hasn't moved in about 1.5 years so I am ready to share the feeling of my accord moving under its own power.
yay!!, you should get us some new pics :)
A18A
Looks like its coming right along. Keep up the good work.
really looks good. now that we have pics i want a video..haha
She's coming back together nicely! Seems like the front of the car is way higher than the back. Could be because you are parked on a hill though. Its good to see the end of this project:) Mine is almost over also
Looking good man, its comming along well. hope we get out for a drive soon :D
yeah she looks good, nice to see her complete again, well not complete, but driveable :D
Hey all :-)
Wow if I didn't know about all the work I've done to this car I'd say it drives like a piece of crap! lol BUT knowing all that I've done the car feels pretty good...
I say that because I'm mainly getting used to the ROCK HARD suspension, if I run over a pebble it sounds like i just curbbed my car! This is due to: Integra Shocks and Springs as well as my front and rear strut bars, and the tie rod set. (picture below)
http://img141.imageshack.us/img141/6411/sbarsuo5.jpg
I've got some electrical issues to work out... My taillights don't work and I've got a grounding issue to work out... this is the little stuff I hate because It feels so tedious.
As for the performance.... I've got about 120 KM on the block now and WOW It's quick! I haven't even stepped on the pedal yet... My car feels like it has V-Tec man... I've got the custom cam from Colt cams and as soon as I hit 3100 RPM it wants to pull and pull... and hard too... which is a tease of course as I can't really get the rpm too high for another 4850 KM lol
Unfortunately my car is not where I want it to be... It only has the Driver seat installed... the Re-upholstering job I did sucks ass so I need to do it again...but this time I've got more experience on my side (the roof looks good still but my A,B and C pillars are falling apart :-( )
I don't have money for new carpet right now so my interior is going to look like crap for a while :-(
All in all it's OK... Not Good but OK. It's going to be alot nicer in the near future when I get some more time and money to put into it.
Gemini2003
i bought the exact same steering wheel for 215
Gemini2003
Hey all :-)
Yes I can realte to the budget thing myself. The hard part is over now. Now its time to relax and take your time
84Accord
what kind of hub are you running? would it work on a 3gee...i want an aftermarket wheel also. and that momo looks like sex
MessyHonda
so use this hub: http://www.modacar.com/products/Hond...b+Adaptor.html
and this steering wheel
http://www.modacar.com/products/Hond...ng+Wheels.html
along with those im running an NRG short quick release. it is about the same distance total with hub quick release and wheel from the wiper and turn signals as the stock wheel was.
id order it from them. great customer service and fairly quick on getting the parts. and they are cheaper than most places
Wow back together at last!! Yay!
Did you get a new oem honda windshield or a replacement one?
man that looks good you going to take the LX badge off? for painting?
(no txt) I deleted my posts.
Started a new thead for the topic. HHO Gas Hybrid Accord
I'll get an update this weekend I promise... with pictures and stuff lol
