Finally got the B20A back! (lots of pics)
Well i finally got my engine back after 2 months and a few problems. But i can finally start assembling it and drop it in the car when i find some time in my tight schedule. I had to use my custom cometic copper headgasket as a last resort and the o-ring process was a pain in the ass. Then when the machinist went to turn it over for the first time he didnt check for head bolt clearance (my ARP ones) and snapped my crower intake cam. So he got the new cam and turned it over and the timing belt would walk off. Turned out to be a combination of the cams being a tad longer and the F22 cam gears being slightly different offset. But i put the stock cams in for the time being and will get it running with them and after i get the crower cams modified i will put them back in.
http://www.imagestation.com/picture/...f/f6fab91c.jpg
http://www.imagestation.com/picture/...9/f6fab8d2.jpg
http://www.imagestation.com/picture/...7/f6fab897.jpg
http://www.imagestation.com/picture/...c/f6fab85d.jpg
http://www.imagestation.com/picture/...2/f6fab7dc.jpg
http://www.imagestation.com/picture/...4/f6fab7b4.jpg
I decided to have it painted gunmetal instead of the aluminum because i liked it better. So hopefully i can get it fully assembled and in the car over the next few weeks. And all i need is a little more money to get the AEM EMS and im done other than tuning/dyno time. Here is the parts list of what went into this money pit:
Fully Built Bottom End
Wiseco Pistons (8.5:1 Comp)
Pauter X-Beam Rods
ARP Head Bolts, and Exhaust Studs
Cometic Copper Head Gasket
New Garrett T3 Super 60 Turbo
Spearco Front Mount Intercooler
Thermal Coated Custom Ludespeed Turbo manifold
Thermal Coated Custom Downpipe
Custom Charge pipes by Justin
Tial 35mm Wastegate
Quaife Differential
Misc Earl's Fittings/SS Braided Lines
Moroso Oil Catch Can
OBD0-OBD1 Conversion Harness from Boomslang Fabrication
Added Knock Sensor
Ferrea Custom Intake Valves
Ferrea B18A1 Oversized Exhaust Valves
Ferrea Dual Valve Springs/ Retainers
Crower Stage 2 Turbo Cams
Full Port and Polish
Skunk2 Cam Gears
Fidanza Lightened Flywheel
Clutch Masters Stage 4 Clutch (Pucks)
AEM EMS
AEM Uego Wide band O2 With gauge
AEM CDI Ignition
AEM 3.5 Bar Map Sensor
Vortec Fuel Rail/FPR
B&M Fuel Pressure Gauge
Vitec Spark Plug Wires
RC 550CC Injectors
Hose Techniques Silicone Hose
ATP Silicone Connectors
