Ok so, I'm getting this lovely noise when I release the clutch pedal. Then and only then does it make this noise. Sounds sort of like a high pitched grindy whine. Does it sitting still and letting pedal out and does it when pressing the gas and letting pedal out. Doesnt do it all the time either which trips me out even more.
Do have a small leak around the shift shaft so I did check the fluid level and while it was a small amount low, only took about one quarter of a quart.
Searched around here doe a while and couldn't find a similar issue that implied the same type of noise. Will get a video here shortly.
