Dual/Twin or Siamese Carbs ??? Perplexed
"Mike" Are you in Washington State or DC, would you care to share your experiences with me offline a I'm doing a B20a Conversion also??
Civvy, Going to be back in the Uk soon. Where do you source your parts from?? as I'm sure I'll be picking up lots of stuff for my B20a Conversion
Ok, I admit I'm a bit of a dense when it comes to Carbs.
When you guys talk about a duel Webber is that physically a single Carb or two units bolted together???
I have a stock 89 DX that I'm hoping to upgrade with an Auto JPN B20a engine from B20aTurbo.
General consensus is that the EFI upgrade is only for masochists.
Slammedaccord has a Weber (assume its a 32-36 whatever that means) I'm hoping to get from him minus the adaptor plate. Is this all I need + the plate and the Auto cable Fix?? Do I need to buy two of them or is there another model called a "dual or Twin" that I need to buy instead.
Ok, You may all laught now.
Thanks,
Simon
