MODIFICATION , THROTTLE BODY ( 4G Accord / Ford 65mm + B16 Manifold / TB Spacer )
PORTING STOCK TB / OVERBORE 4G TB
Well I gave it a shot and bored out the TB I felt some defante gains and will probably experiment with another soon to see the max I can go. Right now this brings the mods list to (not including appearance)
Bomz /AEM custom CAI K&N Filter
MSD 6Al
Accel 14001 Super Coil
Magnecor Wires
NGK Irridium IX Plugs
Colt Cams Triflow Cam
(Specs)
Duration/lift:
Intake 1 260/384
Intake 2 270/384
Exhaust 274/402
DC Sports Headers 4-2-1
Highflow cat
2.25 Dynomax mandrel exhaust
Cosmo Racing FPR
High Flow Fuel injectors.
Bored Throttle Body
Centerforce Dual Friction Clutch
Hyper ground made with monster XL wire.
92 Civic strut bar custom fitted
Project, 4g Overbore Throttle Body
Unfortunately that is yes with a but. I got a 4th gen accord rc bored out TB today it bolts up wonderfull but I am having issues with it. When I first start my car it runs wonderfull but then it starts to do some weird things.. When I depress the clutch the engine stays reved about the same place it was when I hit the clutch and then when I start it idles very low about 200 I have played with the idle screw a little and am not resetting the ecu do you guys have any thoughts.
I need your help 90 accord over bore TB installed a couple problems (pics inside)
First off sorry to the mods if you feel I should have combined this with my other thread BUT I thought it deserved it's own because I now have pics.
The old thread can be found HERE
1) OK IF ANY ONE HAS A 4TH GEN VACUME DIAGRAM PLEASE POST IT.
Ok here is the deal I have the car running it is a hella lot faster and real easy to do BUT the idle is very weird.
2) When I go into nutral or depress the clutch the engine revs to about 2k untill I stop for a sec and it settles down I think it may have to do with the larger vacume line not being used for what it is soposto I am going to diable it and try some stuff tomorrow.
3) Any way I believe the map sensor is getting a weird signal with the new TB so if you know how to reset it or change it please tell me. Other than that as soon as I am able to hit the J/Y I am going to pick up a 4th get MAP sensor and see what I can do.
any way here are the pics (YES I KNOW MY ENGINE BAY IS DIRTY IT IS WINTER HERE LEAVE ME ALONE)
The front of Both TB's
http://www.geocities.com/geezpict2/tbody/top.txt
A side view of the back
http://www.geocities.com/geezpict2/tbody/sback.txt
A top view of the back
http://www.geocities.com/geezpict2/tbody/tback.txt
Not mounted TB colant bypass
http://www.geocities.com/geezpict2/tbody/notb.txt
mounted with out nuts and new vacume line running in (red one)
The vacume port is larger than the 3rdgen one
http://www.geocities.com/geezpict2/tbody/bypass.txt
finally all mounted up ready to go
http://www.geocities.com/geezpict2/tbody/mounted.txt
Hot damn I never expected this power increase (pics soon)
OK here is the deal I have been working on upgrading to a 4th gen TB with somee good luck today I picked up a 4th gen map sensor. I also got some extra plug halves so I would not have to splice anything. All I can say is wow what a huge difference in power and I still have the stock TB on.
There is this sigh near my house coming off my street the besi I have been able to do going past it till today is 70. I was taking the car for a test run I thought I felt more power as soon as I left the driveway. Well on my first try pased the sign at 72 then 73 on the second run and consistently hit 73. Well I thought I would share I don't have it mounted permantly yet just kinda half mounted it is not going any where but I want to make a housing or put it inside the box. Pics later tonight and hopefully testing the new TB out soon.
