Econo all motor rebuild pics
i know its been a while since i've been on the board but its nice to see that the community is growing, but anyways just here to update on some cool A20 stuff. and yes for all u cam gear people they have been ordered and are being made as we speak and will be available shortly.
Well about 2 months ago the a20 that put down 140 wheel hp and with 180k on the clock developed a rod knock which called for a new rebuild. Given the situation we found a good opprotunity to make some nice motor improvements. Just keep in mind that this engine is in no way an all out race motor and is intended to be a daily driver. The new specs on the motor are as fallows:
Standard Ph4 1mm overbore pistons
Stock Rods ARP rod bolts
83.7mmx91mm
Stock valves/springs/retainers
Welded Combustion chambers
P&P head
P&P B16a intake manifold
60 or 63mm overbored LS TB
256/270 cam and probably later on the race cam
Chipped P75 Ecu
This engine is planed to run on 91 octane and pass smog. The welded combustion chambers will give the engine an estimated 10-10.5:1 compression ratio.
http://openloopmotorsports.com/a201.jpg
http://openloopmotorsports.com/a202.jpg
http://openloopmotorsports.com/a203.jpg
http://openloopmotorsports.com/a204.jpg
http://openloopmotorsports.com/a205.jpg
http://openloopmotorsports.com/a206.jpg
