JDMHondaParts.Com Engine Info.
I am going to buy one of these 2 engines, I will start a poll in about 6 months when its time to spend money on which one you guys think I should get...
http://www.jdmhondaparts.com/engines/F20B_1.jpghttp://www.jdmhondaparts.com/engines/H22A-R.jpg
• Engine packages come with the following parts...
A) Complete Engine.
NOTE: Complete Head, block, intake + exhaust manifolds, all sensors, distributor, injectors, alternator, starter, throttlebody, fuel rail, small bolts n' brackets etc., and any other extra parts like AC compressor, intake tube are free. If these extra/free parts are broken in any shape form or fashion, JHP.COM does not replace them.
B) ECU.
C) Transmission w/clutch components (assembled to engine).
D) Axles + Intermediate shaft.
E) Shift linkage.
F) Stock OEM engine mounts.
NOTE: Engine packages DO NOT come with bolt-in kits such as the HASport mount kit.
G) Engine harness.
NOTE: JDM engine harnesses are made for right-hand drive cars. It can not be used in a U.S. car, as far as plug n' play. RHD harnesses are only useful for their plugs and extra wiring.
• Engines have approx. 20-60,000 KM depending on the engine's manufactured year, purchased.
• Any extra/free parts that come with an engine such as an A/C compressor, power steering pump, etc., are not replaceable if found broken or not working. This rule applies to any sensors found broken also.
• Engine packages have a start-up warranty. This means we guarantee the engine will start up with no problems, if you have everything plugged in, wired up, and working correctly.
• Engines are sold in AS-IS condition. No refunds or exchanges.
