rjudgey
Stock engines aren't capable of revving that hi they will go to 7k but younot getting much power and you'll only rev that high in first 3 gears. More often than not it's quicker to shift earlier and use the torque curve to accelerate quicker than ringing the last 1000rpm out the poor engine before changing!!!
If you want an engine that peaks at 7000rpm you need to have headwork, headers, camshaft, and exhaust your not going to get power that high with just headers and exhaust not in all gears anyways. Best test is if you can pull cleanly in 4th gear to 7000rpm at a reasonable rate then you have a good engine that is putting down good numbers but you'll be shelling out alot to be able to do this. And for longevity of the block you really need rods and forged pistons for continual use at 7-7500rpm or the stock rods will break after 20-30k miles worth of use.
