Kind of Scary Problem HELP!
not sure how to word this but here goes. for a week or so now I've been noticing a weird smell in my car (86 lxi hatch), I'm not sure how to explain it but when i smelled it at first it made me think of water, but now its moved on to smelling more like plastic burning or a short or something along the lines of that. I've been messing around to see if i could figure it out but all I've noticed is that it may go away when i turn the fan( inside the car) off, because when i do it kind of disappears but i turn it back on and after a few mins it comes back. i don't think its anything under the hood because if it was i would think it would be noticeable with the fan off or still be there right when i turn it back on. I'm leaning towards THINKING THAT THE FAN MOTOR IS SHORTING OUT OR SOMETHING.if anyone has any ideas or any recalls i should know about please let me know, I'm getting really paranoid because i don't want the car to catch on fire or something since i don't have an extinguisher ,and it also takes 3 or 4 tries to get the hood open anyway.
Re: Kind of Scary Problem HELP!
I had a problem like this, check under your car, mainly your exaust system and see if there is any plastic melted to it. Thats what happened to me, i hope your problem is nothing more serious than that. good luck.
ill check it right away, because this car is my daily driver
$10 extinguisher GET IT! even if you fix the smell that $10 can save you a new car. Everyone should have one,their cheap at walmart or anywhere
I'm not sure on this but, I seem to remember there being an issue with a drain hose for the a/c that if it got plugged up would allow water to backup into the fan housing. I think if you search you should be able to find something on it or maybe someone that has had the issue might chime in.
in the 4 years ive had it the ac has been not working, so unused, but that is still something i will check on. thank you!
pull the fan and blower housing and look inside of it. the resistors that change the fan speed are inside of the housing in the air stream. this keeps them cool, leaves and garbage can get inside of the housing and would make a burning smell on the hot resistors. it's pretty easy to take out the housing and blower unit as one piece. if there was debris in there one of those resistors could also be touching the plastic in the housing. they are fragile and can be moved. they are bare wire. there is some kind of access door to pull out them as an assembly,but if you have crap in there you need to clean it out anyway.
i was told to do this, but i cant find the housing. on my truck it is under the hood but i dont see it there on the honda, would it be behind the glovebox?
86lxihatchb
yep pull the glovebox it's pretty easy it's right under the glovebox all the way up against the passenger side of the dash. when you put it back in put some screen or something over the opening where it sits against the underside of the cowl, after it's out you'll see what i mean.
ok thanks thats going to be the first thing i do when i get home tomorrow.
i always thought there should have been a recall on this,i know last time i pulled mine,had sucked up leaves and some of them were burned. these resistors are bare wire that gets hot like a toaster element. they are in there for the air to cool them. why honda didn't use a multi winding hvac fan, i will never know. instead some of the current goes through the windings to slow down the fan motor. all they had to do was put some kind of screen over the opening to keep out debris.
lostforawhile
yeah my dad said they had the same problems with some older fords too, so ill get him to assist too. thanks again.
86lxihatchb
For Gods sake, oil your hood latch!
the latch is fine, the release is broke
Demon1024
i seen some on like the A pilar of some race cars....or at the ricer shows...but they do come in handy....when my power sterring hose blew it was leaking on the exhast...and it started a fire....right as we were pulling up to honda...my uncle ran and got a extinguisher to put it out. or else the dx would not be with me any more.
so that is what that smell is, burning leaves :bong: in the dash
MessyHonda
Same thing happened to me about 5 years ago...:wtf: That's crazy!
roodoo2
so the moral of this story is........don't hide your stash...... in your dash
as for the topic, even with the fan off i still smell it, but only at certain times.
86lxihatchb
heres some pics, its not in "bad" bad shape
<a href="http://s42.photobucket.com/albums/e316/koticspaceman/?action=view¤t=untitled2.jpg" target="_blank"><img src="http://i42.photobucket.com/albums/e316/koticspaceman/untitled2.jpg" border="0" alt="Photobucket"></a>
<a href="http://s42.photobucket.com/albums/e316/koticspaceman/?action=view¤t=untitled4-1.jpg" target="_blank"><img src="http://i42.photobucket.com/albums/e316/koticspaceman/untitled4-1.jpg" border="0" alt="Photobucket"></a>
a little damage in the back though and a fart cannon
<a href="http://s42.photobucket.com/albums/e316/koticspaceman/?action=view¤t=01010007.jpg" target="_blank"><img src="http://i42.photobucket.com/albums/e316/koticspaceman/01010007.jpg" border="0" alt="Photobucket"></a>
<a href="http://s42.photobucket.com/albums/e316/koticspaceman/?action=view¤t=untitled-1.jpg" target="_blank"><img src="http://i42.photobucket.com/albums/e316/koticspaceman/untitled-1.jpg" border="0" alt="Photobucket"></a>
you did your pics wrong you need to copy the links where it says img codes and paste those
pretty nice hatch man :) and yeah i get a burning smell to i think ima check my blower motor too i know my AC core thingy was full of leaves and dirt so there is a good chance there is some in my blower motor
Dark_Accord
which one lol :( i miss my focus
MessyHonda
cah likes the muffler
it sounds really nice. it complements the a20's tone. its deep and rumbles even in high rpm. dosnt sound a bit ricey and it was only $100
i paid 50 bucks for my magnaflow....looks stock but the cops still pulled me over cuz he was being a jackass
cops escorted me out of a top end neighborhood once because i went to see my girl in my track truck.. :D open exhaust always seems to turn the cops heads around here lol
