i scored some ITBs last week for $50 (came with a free engine too) here's a few pics
http://i241.photobucket.com/albums/f..._8586Large.jpg
http://i241.photobucket.com/albums/f..._8588Large.jpg
my cool tps spacer
http://i241.photobucket.com/albums/f..._8575Large.jpg
using a brake fluid bottle lid :)
http://i241.photobucket.com/albums/f..._8546Large.jpg
and test fitting them
http://i241.photobucket.com/albums/f..._8556Large.jpg
http://i241.photobucket.com/albums/f..._8553Large.jpg
all i've done so far is added the honda tps, map sensor, swapped the injector plugs on the engine loom, bypassed resistor box, swapped all the bolts to honda ones (for extra reliability) blocked off the vacuum manifold, filed the top off (was hitting the head) & cleaned them
all i need to get it running is fuel :Owned:
other things to do are match up the ports, somehow bolt it onto the head with more than 1 bolt and add air temp sensor. could do with a longer fuel hose too since the intake of this one is on the other side of the manifold :@
edit: first thread i made in performance yay
