LxAcc510's pic update thread (56k heyyyyyy)
Re: LxAcc510's pic update thread (56k heyyyyyy)
Bout time you did some mods to that car :lol:
The Visors look sweet
when are you going to install the lip I gave you
can i put a b20 in my 87 accord hatch
Pico
When i figure out what size bolts to use :banghead:
Civic Accord Honda
good stuff!
Tanks! :wave:
Rendon LX-i
Visors ummmmm.
That's what I said:kekeke:
you forgot to say you have tokico blues with lowering springs
Got two nice things at the j/y today.
Prelude wheel.-->pics to come
Accord armrest. (gray)-->pics to come
Did you get your turn signal switch also
87accorddxhatch
lol
those are some mint looking visors!
Pico
oh yeah i got that too. The whole steering wheel switch set...my dad said they broke some stuff in there so we had to get the whole switch unit.
Also got dual filament for the front bumper turn signals. Plan on doing that mod sometime soon.
A18A
lol
yea thanks to 3geez member TypeG ever see him posting ad's i'll tell you now he's trustworthy and prompt. :thumbup:
loook what i found
http://i269.photobucket.com/albums/j...204-0217-1.jpg
:rockon:
They came off an E30 bmw, 15x6 bbs forged aluminum
those look pretty good, good find, i hate it when tire shops put wheel weights on the front of nice wheels... it's not a steelie for gods sake...
nice!!! and hows the 3g doing? haven't seen u around in a while
stat1K
Yeah they're annoying, when i get my tires mounted on these wheels i'll ask if its possible to remove them and if wheel weights are needed to place them inside, but I've been told that sometimes wheel weights can only go on certain spots for certain rims so i might just have to live with it...
Mellexx
Nice find man!
fuck yeah, browsing craigslist persistently pays the f*** off!
Pico
Sweet looking :cheers:
:naughty:
Civic Accord Honda
thanks cah well my 3g's a f'n workhorse, I drive a lot and right now the clock's at 320k and counting. The carb def needs a rebuild, and i probably should replace my ball joints, and I'm hardly on cuz all i do is work at play call of duty =P
That's a good-looking car right there. Good luck with it.
Was it tough to get the Prelude seats in? I'm scouring the junk yards for a clean set to put in my 3g. And does the Cruise Control buttons on the Prelude wheels work or are they just dead buttons?
speedpenguin
thanks, just a few minor cosmetic damages to take care of still though...
Edison Carasio
not really, all u gotta do basically is take of the rails from the accord seats, and the seatbelt plugs, cuz they seatbelts plugs on the lude seats wont work, then theres a total of 2 new holes that you'll have to drill on the rails to match up with the seats, you can basically figure it out by lining up the rails with the bottom of the seats.
When you get the seats at tha j/y though take of the rails there, cuz i think they'll charge you less without the rails
and yes the CC buttons work, you'll see what plugs in when you take off the wheel... good luck
LxAcc510
Awesome! Thanks! Lots of work planned on my Accord. lol and those were two of the biggies for the interior. Already installed an Integra Type R shift boot and knob last night.
You needed a spacer or something for the Prelude wheel, right? I tried to install mine and it doesn't turn right, as it rubs the steering column cover.
I think I messed my Prelude wheel up too. I couldn't see the screws to remove the face and just undid the bottom one and folded the face up to access the bolt at the junk yard. DOH!
Edison Carasio
you need to trim a little off of the back of the prelude wheel so that it wont rub.
Dude pico how come i cant get my wheel to mount straight, and as far as i see I'm lining up the holes the way they should be...no matter what i do it always leans to the left or right =(
LxAcc510
Did you make sure your wheels were straight when u put the steering wheel on?
I've had the same problem. Did you have this problem with your old steering wheel?
If your wheels are centered, I think you might need an alignment.
I took my stock wheels off and put the Prelude wheel on, and then back to stock when it was rubbing and now I have the same issue. I know I need an alignment and the ball joints are bad. I'm gonna try and remount the stock wheel once the weather is warm enough to sit outside and do it. I think I just mounted it a little cockeyed.
And when "trimming" the Prelude wheel so it doesn't rub, how should I do that? Just use a file and file it down?
