lostforawhile
it's actuallly an air injection system, it measures oxygen in the exaust, plus air temp, uses a speed sensor in the speedometer head to tell if you are above a certain speed and several other parameters. there is also a vaccume control mess under the fender thats not even listed in the book, if you just disconnect one thing, the carb wil run rich and your fuel mileage will suck, check on here about vaccume removal, best thing is to put a webber carb on, lots of people have done it, these carbs suck
