out of nowhere i have this brake lamp light on the dash and hand brake light is still on even when hand brake is off ?
check ur brake fluid, could be low...
edit: lost beat me to it, lol.
I have had the float switch in the master cylinder cap go bad which caused my brake light to stay on until I replaced the cap.
I think he has both a brake light indicator on and a low brake fluid warning,both at once
that's weird , this morning turn the car on and the warning lights on the dash bak to normal wtf???no brake lamp light and hand brake light turns off when hand brake released !
Check your fluid level anyway.
mine did the same..turned out to be a loose wire harness....try that...wiggle the harness a bit and have someone stepping on the brakes to see if thats the prob..well first of all do your brake lights turn on??:o
I also had it happen - bulb was going bad and had loose filament - sometimes worked somtimes didn't. Check both stoplight bulbs for dicoloration/corrosion etc.
same thing happen, had low brake fluid. Took me forever to find it. I kept thinking it was a bulb...
the lights on the dashboard turn on not the outside though
OK there are 2 brake related dash lights - one is the "brake warning" lamp. It is just above the right turn indicator lamp. This lamp is normally triggered by the park brake being on, or low brake fluid level in master cylinder.
The other is in the "Safety Indicator" display - where the "door open" indicator is. It is a "Brake Lamp" failure indicator, i.e. it come on when either of the rear stop lights fails (blow bulb).
Which of these lights is stuck on in your car?
The funny thing is that it's all well described in the owner's manual.
FIXED thanks, it was a blown bulb tail light LOL
I'll check that out this week some time. Thanks lost.
Did you check the brake fluid?
What condition are your bulb sockets in?
Not sure of the pass side one, but the driver side and 3rd light are in great condition.
Only good for those whose previous owners kept the owners manual with the car... For me, I don't have a manual, since one never came with the car, and even if it did, as an Ex Japan used import it would have been in Japanese.
Thanks to a search and this thread I'll be topping up my brake fluid, I'm used to it lasting for multiple years without needing topping up on other cars, it's not quite 10 months yet since I bought the car with an empty brake fluid reservoir and it needs filling again. I guess I'll have to go look for signs of a fluid leak somewhere in the brake system.
I dug the centre console apart to check the park switch but that wasn't it.
Its either a slow leak somewhere because you would notice your pedal getting softer or your pads are getting thin
yeah, slow leak, got a set of brake hoses (stainless steel braided) plus a bunch of bushes coming ex Ebay via a friend in Florida.
