Originally Posted by bobafett
its lighter this way, you can still run 13's and as long as you have good rotor/fluid/lines/pads you will not have fade issues. and we all know the stock brakes are good enough to lock up good tires like azenis.
imo 4 wheel discs are a good balanced setup that make the car look a lot nicer, but honestly i doubt the performance is worth it on a more or less stock car. and especially if u autox or track ur car u will not want the added weight.
of course this is just my opinion, i have 86lxi and i plan on upgrading to the bigger fronts and the disc rears. :)
