I needed a bigger hub bearing so I can get a set of Driveshaft shop axles to handel the power. So I took a 91 Integra control arm and had it fit on my car and it worked. So if any one needed bigger brakes or anything else should try it. The only difference is that where the steering rack mounts to the knuckle is about 3/4 of a inch in towards the wheel. I hope this will help someone.
