OK, I definitely claim myself as a suspension newbie and I have the least experience in this area.
So far, for suspensions, I have only changed out all the UCA with ball joints (front and rear), the outer tie rod ends with ball joints.
I am battling with front end vibrations at 75mph. Tires were checked and balanced multiple times to rule out the cause. It is definitely suspension worn out. I changed out the front UCAs and it has helped a lot but the vibration is still there but to a lesser degree. Both axles are intact. However, the bushings are likely original as well as the struts (well, at least for as long as I have own the car for 150k miles).
I don't have much money to spend but I'm changing things one at a time. I think the lower ball joints are probably worn but when I shake the wheels, I don't feel plays.
I know the struts need to be replaced. The rear pass side strut make noise when the car is moving.
There are way too many bushings in our cars and I get confused with them. Also, I know I'm going to miss some kind of bushings or parts if I ONLY buy the struts (like the dust barrel ?, strut top bushings ? lower strut bushings ?)
Ok, what should I replace next for front end vibrations at 75mph ? (Wheels balanced already, UCA replaced and has helped but not eliminated, the bushing on the big side of the "dog bone" wrapped with material to a snug fit) Possible uneven worn front brake discs (those were bought from Advanced years ago) ?
Thanks. -AC
