Rock Auto wholesaler close out. 25 parts, $50.
Check out www.rockauto.com Lots of goodies they are giving away.
ARNLEY 1746905 Distributor Cap
Wholesaler Closeout -- 30 Day Warranty $ 3.83 $ 0.00 1 $ 3.83
BOSCH 04157 Distributor Rotor
Wholesaler Closeout -- 30 Day Warranty $ 0.64 $ 0.00 2 $ 1.28
BOSCH 4307 Spark Plug
Wholesaler Closeout -- 30 Day Warranty $ 0.91 $ 0.00 8 $ 7.28
BOSCH 71579 Fuel Filter
Wholesaler Closeout -- 30 Day Warranty $ 1.00 $ 0.00 1 $ 1.00
FRAM DL3593A (DL3593A:8) Oil Filter
Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty $ 1.18 $ 0.00 3 $ 3.54
GK INDUSTRIES GF211 Fuel Filter
RAYBESTOS PGD334QS Brake Pad
Wholesaler Closeout -- 30 Day Warranty $ 4.76 $ 0.00 1 $ 4.76
SAFEVIEW 19 (19:8) Wiper Blade
Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty $ 1.37 $ 0.00 1 $ 1.37
ULTRA-POWER 42218 Air Filter $ 1.89 $ 0.00 1 $ 1.89
VALUCRAFT VCB19 Wiper Blade
Wholesaler Closeout -- 30 Day Warranty $ 1.15 $ 0.00 1 $
Re: Rock Auto wholesaler close out. 25 parts, $50.
I don't think I would put any of those parts on my car, save for the fuel filter and the air filter... Seriously, the good parts are like a couple dollars more
I don't have a good suggestion for the dizzy cap, but they aren't a lot of money and brass lasts longer
Standard motor JR89 dizzy rotor is also on wholesale closeout for $1.76 and its brass
Denso 3032 spark plugs are $1.34 for a whole 4 pack and aren't double crapnum
Wix 51334 oil filter is $4.46 and the only filter I'd recommend you buy because its cheap and safe
Wagner MX334 brake pads are $5.83 and I have never seen them over $8 in the whole time I have owned my car. I would even take these to the track.
And wiper blades... seriously, don't cheap out on wipers unless you live in the desert, and even then you should replace them yearly
Keep an eye out on those wholesale parts... a lot of the time they don't come from the same warehouse and you can add another $7 shipping.
Very good points. The car only gets used a couple months in the summer so I just want some back up and disposable parts.
I did discover a 22 inch wiper blade fits on the the driver's side.
Bought all from the same location so only 11.99 shipping for everything.
I've bought all types of plugs for it and it doesn't seem to care for the most part. The simpler the better.
Those bosch plugs are far from simple, double platinum, thin electrode, dual electrode, which is notorious for blocking out the spark and doing absolutely nothing for combustion. Copper plugs is as simple as you can get, just buy decent quality ones from Denso or NGK with plated threads.
