As the title says. It's dripping down onto a hose of some kind (heater hose?) and my PS rack. Seems to only leak when the car's been sitting for a while after being driven. Any ideas?
hard to say with out a picture but the distributor has an O ring seal that can leak oil out.
If it is really just the rear of the engine...towards the firewall. The oil filter housing has a figure 8 O ring that can go bad.
Don't forget about all the PCV hardware back there that develops leaks.
Check the oil pressure switch.
Pcv is also through the rear, specialty hose with two different IDs
Thanks for the tips, ever since I had a new pan/pan gasket put on the car the leak has become really tiny. It was a lot worse before then. BTW is synth blend oil bad for these cars? Paranoid that it's going to gum my motor up or make it leak even more oil.
