Cruise Control Main switch and Dash light dimmer switch
Hi !!
I'm looking for the Cruise Control Switch mounted on the dashboard just above the fuse box. Mine goes intermittent and may be about to end its life soon.
Am also
Looking for a good used dash light dimmer switch. Mine will no longer dim but stays on for good.
Good working condition please and reasonably priced , send to 90723.
TIA
Re: Cruise Control Main switch and Dash light dimmer switch
Might be worth a look inside that Cruise switch. Most likely you can resurrect it with some emory paper, silicone grease and some minor tweaking. Good luck with the repairs.
Thanks dr snooz. Was thinking of opening it up. But best amd instant solution would be to have a good working switch replace it. Cant find any used anywhere.
Hidden lights
i may be able to help.... i have a parts car with cruise control and i also have the dimmer switch. are you still in the market?
