1982-1983 Accord Heater Valve onto 1979 Accord Heater Core/Box Retrofit
Hello everyone,
So my heater core and valve started leaking recently and I had to replace it. Unfortunately I couldn't find a new 79-81 valve so I replaced it with an 82-83 valve. I didn't get pictures of all steps so read this start to finish before you do anything if you do it. I've had 0 leaks so far. Here's the process:
Cut the bottom pipe down to make room for the valve
http://i.imgur.com/19lNH7Ul.jpg
Remove the old valve from the bracket and notch the bracket for extra clearance as shown
http://i.imgur.com/2sySuTal.jpg
Your stuff should now look like this
http://i.imgur.com/uT8QIUwl.jpg
Which allows the valve to slide right in
http://i.imgur.com/YQOwxdnl.jpg
The 82-83 valve should have almost all of it's bracket removed. Leave a ring so you can JB Weld it to the old bracket
http://i.imgur.com/U9GVh2wl.jpg
http://i.imgur.com/IRTTPIFl.jpg
http://i.imgur.com/ugBixOHl.jpg
Re: 1982-1983 Accord Heater Valve onto 1979 Accord Heater Core/Box Retrofit
JB Weld the valve to the old bracket
http://i.imgur.com/sD4n979l.jpg
http://i.imgur.com/8ea4Utll.jpg
http://i.imgur.com/2rutjfCl.jpg
Dry install the valve and check to make sure that the valve opens and closes all the way as the flap moves. Note that I also had to remove the left side of the adjustable bracket so the screw could be set far enough out for full travel. Click for super high res so you can fully see what's going on
http://i.imgur.com/UJudCnil.jpg
http://i.imgur.com/5W8q0kkl.jpg
http://i.imgur.com/14cBtEVl.jpg
http://i.imgur.com/IhXHgBgl.jpg
Put some new hoses and clamps on and it's ready to party. Click for super high res
http://i.imgur.com/e0GSurKl.jpg
Good luck!
Thanks! The 82-83 valve is really easy to find on ebay and I think this is a good solution if your valve is all blue and nasty.
I have an stock of those NOS valves... :squint:
Good job btw!
