ohhh, I've been looking all over weber sites trying to find some kind of jet or something. Thanks for clearing that up.
Hi
I might be a bit off topic but I was wondering if anyone has any suggestions on the jet sizes for a 38 DGMS considering it will be on a Cologne 2.8l V6.
Thx
I believe that motor came with a 38 (one I had did anyway) and oem jet sizes are published in the weber book, which I don't have handy at the moment but will post them here in a bit since that would be beneficial to us too if someone lucked up and found one in the junk yard.
Capri 2.8 early models...search MK3 performance maybe ..Mains 142, airs 185, idles 45, em.tubes F50, pump 55 is going to be close.
Ok this set up is not tested with a wideband but it REALLY woke up this DGV-5a 32/36 on an otherwise stock A20A1. This thing has a hellova relentless grunt now..no bog and pulls hard from a dead stop to full thottle through redline.
This is on a 5 speed car and I dont know how well this would work on an auto, not the pump jet anyway. There is some secondary enrichening there that may not always be needed but certainly has an exciting effect.
--Primary Main Jet = 150
--Secondary Main Jet = 140
--Primary Air-Correction Jet = 180
--Secondary Air-Correction Jet = 165
--Primary Idle Jet = 60
--Secondary Idle Jet = 50
--Accelerator Pump Jet = 70 dual outlet
--Primary Emulsion Tube = F50
--Secondary Emulsion Tube = F-50
anybody got an recommendations on jet sizes for dual Weber 40 DCOE's? with a few other bolt-ons as well, if that changes anything...
He is the jet settings i was running without a wideband... def something to start at if you have basic mods.
Here is what I had mod wise... Delta 285 cam regrind. Bored out to 81mm S&S headers...
Accel pump jets, 45
Accel Discharge, 45 (took out my soldered closed discharge)
main jets, 140
air correctors, 200
emulsion tubes f7
idle jets 50f9
Ran like a bad out of hell with even super low compression in one of the cylinders. It even pulled my b16a prelude with these jets, and it didn't have any problems revving up... you know like when you initially get on it, no dead spots...
and that was with 40mm chokes
When I first ran my 38 I had no coolant hooked up to the manifold, and cold start warm-ups took ages. The carb really does not like to be cold, and just the temp changes from noon to evenings really affect the tune. Life’s a bit easier now with the coolant running through the manifold.
Regardless, tuning this thing has been a roller coaster. I finally actually understand the carb though, and I’m sitting at a good spot. Engine is an A20A1, modified intake manifold, 88-89 LXi exhaust manifold, 272 duration camshaft, Weber 38 carb.
--Main Jets = 127
--Air-Correction Jets = 200
--Idle Jets = 0.57
--Emulsion Tubes = F66
My mains may seem lean, but according to the AFR gauge it’s what the car wants. I might be able to run larger ones with a larger air corrector, but it’s the perfect mixture at WOT right now. It actually gets a little rich in the high RPMs wide open. But that’s the least of my concern. My biggest problem has always been partial-throttle lean out. Took me forever to figure out it’s because of the progression circuit, and even then it’s still been difficult to nail a good tune.
To get the perfect idle mixture AND proper cruise mixture (which by the way, Cygnus mentions the cruise mixture is controlled by the mains, I disagree. Changing my mains did nothing for cruise mixture, but idle jets changes it every time. That’s because they also control the progression/transition circuit) has been the biggest challenge. For a while I had 0.60 idle jets, as that’s the only way I could eradicate the lean spot, but cruise mixture was way too rich and mileage was bad (11.0 cruise, 200 miles from full tank). So I tried 0.55’s down to 0.45’s. 0.55 and 0.50, I could idle a healthy 13.8-14.2 with the idle screws 1 to 1.25 turns out, but the progression circuit (at cruise) would lean out from 15.0 through 17.0. So between the 0.55 and 0.60, it was either lean out at cruise or too rich at cruise. I’ve been pulling my hair out about it, and as a last ditch effort I ordered the 0.57 idle jets. Best I can say is it’s “better,” but not perfect. I think about 3/4 turn out on both idle screws. Cruise is closer to 13.5-14.2, progression circuit still leans out but only if RPMs climb (like if I leave it in 2nd with partial throttle at 30MPH) so if I just drive it right I can avoid it. WOT is perfect (14.5-13.5) until about 4200 RPM it hits 12.5. Which I don’t understand with the mains being as small as they are and the engine using a longer duration cam…but I do have a set of 125’s so maybe I’ll try those but I feel like I’m going to run into a different kind of lean spot if I keep going smaller. I don’t understand how other people are able to run such large jets even on a stock A20, like I know no engine is exactly the same but what the hell lol.
I dont know the inner workings of the webers too well, but it sounds like to me that you immediately pointed out a problem
Pilot jets should not have a significant difference on cruise operation because once the throttles are open, it creates low pressure in the barrels, pulling fuel from the venturi. It needs to do that because the pilot jet is not a variable flow, it just shoots fuel through the hole with the fuel pressure. So, dont compensate with the pilot jet, set your idle afr according to the Redline manual and dont touch it after that.Quote:
It would help to know: Is your carb new? What other jets have you tried? Are you in high altitude?
I would suggest getting this carb ultrasonically cleaned if it is not new. Reset the main jet to something normal like a 140. Set the idle.
Maybe this has something to do with the air correction jets, not familiar with them, but knowing that fuel flow out of the venturi is based on a pressure differential around it, maybe there is something up there, so there is very little flow at low throttle percent. Maybe the air correction jets are too large or the emulsion tubes need to be larger. As far as the lean out on accel, that might help, but the accel pump might need retuned after cruise afr is somewhere reasonable. Also, if you are in high altitude, try to tune it somewhere a few hundred feet lower if that isnt too far from home, it will be easier to find a baseline.
You arent anywhere near either of these setups... have you tried anything similar?Quote:
38 WEBER
38 DGAS
Idle Mix Screw: 0.75-1.0 turns out.
Both screws should be as equally balanced as possible.
More then 1.0 turns and you need a larger idle jet.
Synchronous carbs must use the same size idle jets.
38 DGAS
Bogging problem in the upper rpm?
Try F6 emulsion tubes and slightly smaller idle jets to change the fuel curve.
The emulsion tubes will bring the main fuel curve down a bit lower and allow the engine to use it when vacuum is at a decent level.
The upper rpm will lean out just a bit, if needed smaller air correction jets can richen the mixture.
* The 38 weber came with these jets on a different car of ( 2994 cc ) ours is ( 1955 cc ).
(38) JET SIZE x2 , except for Pump Jet
- 1.45 Mains
- 1.85 Air Correction
- 0.50 Idle jet
- 0.65 Pump Jet
- F50 Emulsion Tubes
You may want to make a collection of jets, remember this is a synchronous carb.
There are two easy ways to richen the main mixture
Air Correction Jets ( Smaller # = Richer Mixture )
Main Jets ( Larger # = Richer Mixture )
A lot of the times I see the Air Correction dropped VS increasing the mains to get a richer mixture.
In some cases the mains are the restriction and must be increased, the air correction may be left unchanged or increased.
The idle jets meter fuel flow for the idle circuit as well as the progressive circuit. The progressive circuit consists of multiple passages right above the idle passage, which are activated with minute opening of the throttle plates (cruise position).
The carb is new, non-ethanol gas only. I have tried similar setups with rich results (which is what trips me up lol, since I don’t have a stock cam).. Since my last post I bumped up my mains to 135. WOT is too rich again but the lean flat spot is gone and cruise is about perfect. Despite all of that, this is the best tune I’ve had so far and I plan to leave it alone until necessary. At the point I want to try larger air correctors. Oh, and I’m right at sea level. I’m no carb expert but this is just what I’m experiencing. Having fun learning the 38 though
