Re: Are there any transmissions that bolt directly to the A20A?
86 Accord lxi hatch with jmba7 badge here, so do i have a bt engine same as 1986 prelude si?
All hub splines and tranny splines, and cv axle lengths are the same for every 3geez? accord, and prelude? I worry. I need to swap my transmission 5spd too and Id love to use a prelude 5spd but is that front end width the same? Cv axles from my accord going to fit or do I need axles for the prelude car and will those fit into my accord wheel hubs?
Pretty sure it's the same, but I would worry about trying to find that trans instead because good luck with that
Verify the splines fit the diff and use the accord axles, the trans case is the same so it would fit the same otherwise
