well I got a few extra ECU's, have to hit up the j/y for the OBD-1 plugs
seems to me that rewiring plugs for OBD-1 is just asking for trouble. besides, it also seems like a lot of hassle. I'll spend the 100 bucks and know that im getting it right the first time.
Hmmm I will have to definately check into this when I get done with my carb to efi swap. Since I'm crossing over to the darkside I better get ready to start a turbo project by getting parts here and there for a longtime since I have to save up for a house and a wedding.
Are the OBD-0 to OBD-1 conversion harness's available a direct fit onto our existing harness/plugs?
Yea all the OBD-0 ECU have the same plugs same with the OBD-1.Quote:
Originally Posted by thegreatdane
So after someone has everything how much work would it be? And would you need to be really good with cars and wireing? Or just a little bit of brains will work?
I want more people to get into this.I thought if we show it's not to hard we can interest more people.
www.boomslang.com he will make you what ever you want and he made my harness custom for the b20a obd-1 conversion for the AEM EMS. All he needs is a wiring diagram and what you want and he will do it.
justin already has all the stuff for the conversion except a P06 ECU. The F22a6 distributors also have external coils which is good. Now all we really need to test run this setup is a base code that will work for the a20a because nobody can get the a20 code from the ECU.
Don't forget 4-wire O2 sensor that the P75 will be looking for.Quote:
Originally Posted by Justin86
You are right; the plugs are the same, but the pin locations/functions can be different between different ECUs.Quote:
You should not need the A20 base code, because you won't be using the A20 ECU (PJ-0). If you are using the P75, our engine should run fine off it's base maps. With applications like Uberdata added, these can then be manipulated to exactly fit our cars, NA or boosted.Quote:
Originally Posted by NXRacer
Once you get an OBD1 distributor, the rest is pretty easy. You need to get a good wiring diagram of the ECU you want to use and the diagram for your car. Neither are too tough to find, then you start matching up. The nice thing about honda ECU's is they tend to use the same wires in the same pin location across ecu generations. For example, the MAP sensor will be pins c15,c11 and c14 on all the Honda OBD0 ECU's I have seen. When I put the Prelude PK2 ECU in my car, 90% of the wiring matched up, and I know the Prelude guys are replacing their PK2 with OBD1 P75 Integra ECU's with just a conversion harness, so I should be able to as well (and I plan to).Quote:
Originally Posted by Elijah
Bottom line is this is not rocket science and a lot of people have been working on Honda ECU's for a long time (just not for our Accords). Once we find a solution to the OBD1 distributor, the rest will be pretty easy.
Gregg
ok the ECU will be easy to get online same with the O2 sensor. I have the OBD-1 harness, but as to which wire goes where I have no clue and can't find a pin out for the ECU?
Do you know which ECU you are going to use? For example, if you chose the P75, then you need to find the wiring diagram for a 92-95 Integra. I'll poke around and try to find the diagram since this is the ECU I plan on using as well.Quote:
Gregg
If you guys are going to use the OBD0 to obd1 conversion harness, be prepared to add wires to your existing harness and swap some pins on the harness (like I did)
Also, like I said, you do not absolutely need a 4 wire Sensor. the heater can be disabled in the ECU program.
well I could use either the P06 or the P75, I'm just waiting on some help for the wiring from cartman, cause I can get either ECU no problem.
well I did some searching and found a pin out for the OBD-1 harness, and the entire ODB-0 to OBD-1 swap. He used a VTEC ECU and different dizzy and there is some differences depending on different yrs. But this is a very good start. http://www.pgmfi.org/twiki/bin/view/...KurtsOBD0-OBD1
The 88-91 civic/crx and 3g accord/2g prelude wiring schematics are very differant. It's doesnt really apply to this swap.
carotman- you got more info?
-david
well most OBD-0 systems are the same, but there is some differences. Some control more and some less. I'm trying to work out the differences between the systems right now. Mostly cause the OBD-0 to OBD-1 conversion harness is not made just for your model it is suppose to be universal for all OBD-0 models. So if pin B14 controls the alternator on the accord, but on the CRX it controls the main relay, there is going to be some problems with these all ready made conversion harness, since it is suppose to work for all OBD-0.
So the link I gave should be good so far until I have more time to completely pick through it to look for any differences that will cause us problems if someone bought it.
Not quite true. I've got an Exel file with our PJ-0 (obd-0) and a P-72 (obd-1, very similar to P-75) pinouts. If anyone wants it, pm me.
What year is the PJ0 pinout?
88-91 is obd-0. our cars are pre-obd. i compare the wiring diagrams once. they are differant.
obd-0, pre obd is the same thing.
Hey Justin, do you have a good source for the P75 in Oregon? I am looking for one right now.Quote:
Gregg
Well here in town there is no more P75, and they want $100 for any ECU some are more. I'm going back to look at some civic's that I belive have the P06.
OMG rob you have had a pinouts all this time..........
from what i've been told the P06 is probably a better option then the P75.
No, I've got pinout for the P-72. Very similar to the P-75, but there are a couple wires that are different. I was waiting to do mine and get it right before I posted. Try to save anyone else from having to reinvent the wheel. Just haven't gotten around to it yet, 'cause I'm still building the engine. If you guys figure it out first though, please be sure to post it.Quote:
I don't see why that would be. You have to still do a wire converion, and find a distributor to fit, but you still end up with an OBD-0 car. For the same amount of work, you could have OBD-1 ECU control for better/more tunability. P-06s are probably easier/cheaper to find though. I guess it's just up to what you want.Quote:
